Heavy bag stand for local gym
发表于 2021-9-1 00:14:22 | 显示全部楼层 |阅读模式
DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:nice flames in last pic. good job on the stand also.is that a plate for mounting a speed bag on the right?Last edited by Corey72; 12-15-2008 at 02:43 PM.
Reply:Another item that makes a nice heavy bag stand for personal use is an A frame used for changing out engines.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Originally Posted by Corey72nice flames in last pic. good job on the stand also.is that a plate for mounting a speed bag on the right?
Reply:Just had another thought??Before my MS took me away from the martial arts I was pretty active in the harder straight line forms that stressed power in both hand and leg techniques. Looking at the unit you made you said it will be used for heavy bag. Is this going to be used for boxing mainly? Reason is that unless the base of that unit is bolted to the floor almost all heavy punchs will cause  it to rock. And heavy kicks will cause it to tip over. Leading me to think it would need a bigger base for stability or the existing base will have to be bolted down.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Looks like a fantastic job with the tubing.  Paint came out good too, just like the bumper.(My neck hurts, and I had a helluva time seein' the beer cans)"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Looks professional to me!David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:I think it'll be used mainly for boxing, the guy at the gym didn't even really know what he wanted so this is what I came up with.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:It looks like a great solution for men who come to the gym.  Finally they have a place to put their "Old heavy bags" so they can have a peaceful workout.  Mind you it probably should be renamed the large spousal arrestor or something like that.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-23 01:01 , Processed in 0.113655 second(s), 18 queries .
