this weekends side job
发表于 2021-9-1 00:14:21 | 显示全部楼层 |阅读模式
here's a little wrought iron piece I did yesterday Attached Images
Reply:another pic Attached Images
Reply:You fencing guys are awsesome.  Looks like you did the scroll work too.  If so how do you forge the ends?Great job.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:The scroll work looks store bought to me.  What's the long leg for, concreted in the ground?  Looks good, I like capped railing.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:where's the wrought iron? I see lots of steel but no wrought iron. Just giving you a hard time. It does look good where do you get the cap and scroll?
Reply:Nice job.....Mike
Reply:Cool.Is that body filler?A butterfly without wings, is just an ugly bug
Reply:the scrolls are store bought, I guess your right about not really being wrought iron, if you want to be technical, this type of fabrication really isn't my forte, but I kinda enjoy doing it when I get these jobs. the leg will get shortened. the last time I did fencing I had a jig, this one was pieced together since this one is so small and was only one
Reply:Originally Posted by Magnetic MechanicCool.Is that body filler?
Reply:i love well built anythings.kudosinsert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:Looks assume man, you do good work. Welds look great as well. Everything looks nice and lined up, I know that's not easy! Keep up the good work.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
GMT+8, 2025-12-23 01:00 , Processed in 0.068032 second(s), 18 queries .
