My latest sculpture
发表于 2021-9-1 00:14:21 | 显示全部楼层 |阅读模式
Tension Attached Images
Reply:Cool!Are there magnets on the ends of the "spokes" and on the "rim"?Rex
Reply:Originally Posted by rode2rouenCool!Are there magnets on the ends of the "spokes" and on the "rim"?
Reply:That's cool....I wonder if I can make my eagle levitate???If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:I like it, has that 'surreal' look....Mike
Reply:Thanks.Hardest thing: polishing that stainless steel, especially after the HF ring roller put the teeth marks from the knurled rollers into it when rolling. The flat bar came in standard mill 2D finish. Starting with that, and adding teeth marks, it is an enormous pain to get it to reasonable finish...Does anyone know where I can buy flat SS bars that are #4 finished?
Reply:REal coolI wish you would not have posted this. I have to make one.for class. Are those neodymium magnets?
Reply:Originally Posted by ReebsREal coolI wish you would not have posted this. I have to make one.for class. Are those neodymium magnets?
Reply:What kind of wire is that and how is it attached to the magnet - does the magnet have a hole in it? Neat project!Fire!, Fire! Oh wait, that's my torch...Lincoln PT-225 TIGLincoln 175 MIG
Reply:Are you Bruce Gray?Looks a lot like his stuff.
Reply:Originally Posted by RAWAre you Bruce Gray?Looks a lot like his stuff.
Reply:Originally Posted by VipernutWhat kind of wire is that and how is it attached to the magnet - does the magnet have a hole in it? Neat project!
Reply:Once again I have to make one. I teach a "teacher physics workshop" the next topic is magnatism. Any tips you can give or even part numbers.Very cool looking. Thanks for posting.
Reply:Very cool, nice work.Miller Dynasty 200DX Tig Welder
Reply:Originally Posted by TerrHm. Interesting. Haven't seen it before, and yes, looks like his. I guess great minds think alike.
Reply:I do alot of polished stainless work and have never seen #4 finish bar stock before, im pretty sure thats specific to sheet.  What did you use to finish it? a nylon mesh grinder wheel and some 200 grit flap wheels would make quick work of that.Have we all gone mad?
Reply:A medium scotch brite pad that mounts to a drill gives a nice and consistant satin finish - I've used it quite a bit on aluminum, but it should give similar results on stainlessFire!, Fire! Oh wait, that's my torch...Lincoln PT-225 TIGLincoln 175 MIG
Reply:Originally Posted by sn0border88I do alot of polished stainless work and have never seen #4 finish bar stock before, im pretty sure thats specific to sheet.  What did you use to finish it? a nylon mesh grinder wheel and some 200 grit flap wheels would make quick work of that.
Reply:so go from 60 to 120 to 200 then mesh wheel and polish, mirror finish everytime.Have we all gone mad?
Reply:fraud haha
GMT+8, 2025-12-23 01:01 , Processed in 0.072552 second(s), 18 queries .
