turbo burn barrel
发表于 2021-9-1 00:14:20 | 显示全部楼层 |阅读模式
cut 7 shapes in the bottom 3rd then hammer them in when the flame gets going it starts spinning like a turbo jet fan Attached Images
Reply:cooli like to take long straight sticks and put them in my wifes Chimenea (spelling )when i get the chimney packed tight i light it and it makes like a jet engine. dont do it if you like the chimeneainsert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:Y'all are pyros"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I LIKE IT!  Jet powered trash burner.If I knew that I was going to live this long, I would have taken better care of myself
Reply:You can also do the same with old oil tanks. And they hold alot of stuff. Should see it burn lath from an old house. Looks like that afterburner on an F-15.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:That is sweetMiller Dynasty 200DX Tig Welder
Reply:You've given me an idea. I know a welder who has an incinerator like that but he's only cut a flame pattern in the middle third with the plasma. It's hopeless for burning anything, on account of no draft. I've told him he needs the flames on the inside but he's too tired to do anything. I might just copy your idea and give it a whirl."One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:That's a great idea. I can't use it because it is illegal to burn trash here. You can run a smoker or a wood stove or a chimenea (?) but if you get caught burning your trash is it a big fine. Go figure.
Reply:I like that!  I will build one tonight.  It is 8 bazillion below zero here in sunny montana, this should warm the soul.  Happy Holidays.
Reply:I use old hot water tanks. Put some legs under them and a larger hole in the bottom middle with smaller ones all around it, a few designs on the side low and let the burn begin. Great for sitting out on a cool nite.Brett B & B Fabrication and Welding Inc.Spalding, MI.
Reply:Amazing...
Reply:love to see a video of it burning, idea sounds awsome, does it shot sparks up into the air aswell? gotta be carefull where that **** lands
Reply:One of my personal favorites.  The real turbo burn barrel.http://www.gas-turbines.com/nt6/index.htmlDynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:Originally Posted by OldtimerThat's a great idea. I can't use it because it is illegal to burn trash here. You can run a smoker or a wood stove or a chimenea (?) but if you get caught burning your trash is it a big fine. Go figure.
Reply:Originally Posted by captdave2612I was called out on a trash fire three years ago. When I arrived at the location I explained to the homeowner (that was setting with his friends drinking a beer) that you can't burn in Harris co. I told him the exemptions cooking, celebration (organized bonfire) exedra..... He said hold on a minute walked inside and came out with a whole chicken threw it on the fire and just stared at me. My crew busted out laughing. His friends did more of the same. The only thing I could think of was to say works for me. When we got back to the station they were still laughing.  ...
Reply:Last summer I experimented with adding air to the fire pit, but I went with mechanical supercharging.Attachment 26532It really enhanced the burn, but unfortunately I was interrupted before being able to completely evaluate the results. You see, the same night I was testing, the neighbors woods caught on fire, and after the interruption, I just never got around to completing the experiment.Last edited by denrep; 02-25-2009 at 01:07 AM.
Reply:denrep: Why does that look like a baby carriage that's on fire??Where is Junior???  -MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Originally Posted by Mondo...Why does that look like a baby carriage that's on fire??Where is Junior???
GMT+8, 2025-12-23 01:07 , Processed in 0.099009 second(s), 18 queries .
