There must be.....
发表于 2021-9-1 00:14:19 | 显示全部楼层 |阅读模式
A neat little wrench specially made to loosen and tighten the collet body on a TIG torch. I could make one I suppose. I noticed this weekend that I ruined one of these nuts from using an adjustable wrench. Anyone have this tool?
Reply:I just use my fingers.????????????????????????Never had a problem.
Reply:It is important that the collet body is snug, and that the back cap/collet/collet body all securely hold the tungsten.  Generally I think most people use their fingers, a little wrench would be ok too.  Maybe your talking about the short little collet bodies which have flats for a wrench.  These may snug up best with a wrench.  Then again, why not just use a gas lens and get the best shielding?  The main problem would be loose components causing arcing or overheating from excess resistance.
Reply:wrench?for a tig collet?  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:jsut use your fingers like the rest of usChuckASME Pressure Vessel welder
Reply:Maybe have your big sister tighten it for you????
Reply:I've been just using my fingers to snug these up lately like you guys suggested. Of course this works nicely. I don't know what made me think I had to get it much tighter. Now I don't need my big sister to help...
Reply:This guy can helpDrivesector Hobart Handler 140Hobart Handler 180Ready Welder 2Hobart Air Force 400Airco Stinger 225Of all the things I've lost, I miss my mind the most."OZZY"
Reply:Fingers will do nicely.
Reply:Originally Posted by drivesectorThis guy can help
Reply:i use a dremel tool wrench on mine but dont use much torque. the only reason i use it is due to extreamly dry hands to the point of cracking. the dremal tool fits nice and is small enough it should keep you from over tightining it. just give it a lil tweek and its good to go. summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
GMT+8, 2025-12-23 02:17 , Processed in 0.092535 second(s), 18 queries .
