o/a hardfacing
发表于 2021-9-1 00:14:18 | 显示全部楼层 |阅读模式
I have gone back to hardfacing my cable tool well drilling bits with the torch. I have uneven rsults with this-sometimes it won't stick. Do i need a puddle on the bit steel? This goes around the outside edge where there is alot of abrasion, and when i get it , it wears very well. Of course the bit is usually hanging on the machine, meaning a horizontal weld.thanks
Reply:My Dad had A C/T rig when I was very young.Watched him resize bits w/ forge and sledgehammer.Is this still done?Fascinating to watch.  I'm assuming you've tried stick welding the hard rod. Have you tried welding "dots" of hardrod instead of beads. I know some types of hardrod are hard to run horizontal. I always had good results  w/ Stoody hardrod on heavy eqpt buckets & dozers. Keep the amps down low enough to just form a good puddle.   With torch it probably takes a long time to get enough preheat to get rod to stick since there is so much mass to heat. JUst guessing,maybe someone else has a better technique.                      MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by dendrillI have gone back to hardfacing my cable tool well drilling bits with the torch. I have uneven rsults with this-sometimes it won't stick. Do i need a puddle on the bit steel? This goes around the outside edge where there is alot of abrasion, and when i get it , it wears very well. Of course the bit is usually hanging on the machine, meaning a horizontal weld.thanks
Reply:Check this link out.http://www.thermalspray.org/site_industryserved.asp
Reply:Thanks for the tips fellas. Never thought of using acid but that makes sense. I have a friend who forge dresses bits with his dad, then they use the borium gas rodon the lower outside edge where you need it-you keep a flare there so the bit doesn't wear into a wedge shape, cause then you get it stuck! If there is a bead there where you can localize your heat the borium sticks fine just sometimes that wears off before you know it.
GMT+8, 2025-12-23 02:19 , Processed in 0.094529 second(s), 18 queries .
