the good ,the bad
发表于 2021-9-1 00:14:16 | 显示全部楼层 |阅读模式
tell me the good the bad.thanks ahead of time.these are fcaw-gs1/16 wire.3 passes.3/4 plate. Attached Images
Reply:the pic is confusing..what exactly are we looking at?what did you weld together and at what angle?2 flat pcs? a flat and a flat to make a "T"?..or "L"?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterthe pic is confusing..what exactly are we looking at?what did you weld together and at what angle?2 flat pcs? a flat and a flat to make a "T"?..or "L"?...zap!
Reply:3/4 huh..thick plate..how many passes and how "hot"?.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapster3/4 huh..thick plate..how many passes and how "hot"?.....zap!
Reply:well then they gook real good for fcaw @350..spatter is minimum..there even..no high spots..lookin' good... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Looks like you're running hot enough. Good wetting out, flat bead, straight along the edges. You must have a steady hand
Reply:Originally Posted by zapsterwell then they gook real good for fcaw @350..spatter is minimum..there even..no high spots..lookin' good... ...zap!
Reply:Originally Posted by SandyLooks like you're running hot enough. Good wetting out, flat bead, straight along the edges. You must have a steady hand
Reply:pretty good,, make that bottom pass bigger next time and then the top one will go on a lot easier.  you have little dents it looks like in-between those two passes, it looks like you just jerked your arm a tiny bit or something,, over time you will work that out.that first bit there your two passes fused beautifully,, if they were equal size i would call that perfect,i really noticed how your edges smoothly join into the plate,, nice
GMT+8, 2025-12-23 02:15 , Processed in 0.190593 second(s), 18 queries .
