House trailer frame made into trailer.
发表于 2021-9-1 00:14:15 | 显示全部楼层 |阅读模式
I was wondering if a house trailer frame would be suitable to cut down and make a trailer. Frame is supposed to be 10' X 60'. would cut down and make 1-5' X 10' trailer out of it. Should have enough steel to easily double up on everything. Frame is 60 miles away and am wondering if it is worth it. Anticipating hauling riding mowers and occasional firewood on it. Yeas or nays? Thanks for any advice.
Reply:Most of ‘em are a special really wimpy "I" that's much lighter than a Junior Beam, mostly depending on the house for strength.Although for a light short trailer it'd probably do.But... 120 mile ride for a long, flexing, bouncing, stripped chassis and them dealing with the trailer's lightweight beam and its tall web and the  extra reinforcement it's gonna need... I'd pass and size the right metal for the job.Good LuckLast edited by denrep; 06-15-2011 at 11:20 AM.
Reply:Also the axels will need to be shortened.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:60 miles does not seem very far....here in the middle of Texas... If you could figure out where you were going to want to cut it....and they had a way to stack the cut off section on the front part... I would sure go get it.. but I would not try to pull it with it in one piece due to the huge overhang aspect...   I have one here I am in the process of figuring out how to utilize... it was burned so parts of the I beams are not totally straight.... I am hoping to make it into a portable band saw mill....Weldandpower Lincoln 225 AC,DC with Briggs 16hp gas engine.WW2 era Miller TIG.
Reply:becareful using MH axels with those tires (14.5 wheel/tires ,,,,they are outlawed in Oklahoma  ( check your state lawsyou can swap out the hubs for luged wheels with 15 or 16 inch tires and be okthe reason i was told ( form the motor vech. dept )was that the tires and wheel are for one-way transport of the homeidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by GBMit was burned so parts of the I beams are not totally straight.... I am hoping to make it into a portable band saw mill....
Reply:Denrep is correct about the I-beams, and the axles are pure junk. They might make very nice fence posts though. Steel is always reusable, but is it worth your time? The return from the frame metal may not yield stellar results, because it is very thin.Scrap value might not be too bad. City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Not worth the trouble, start with fresh material, build a proper trailer, don't jury rig something together.72 Chevy Cummins Project94 3500HD Welding Rig build Sold NOV 2011
Reply:Originally Posted by NiteskyBURNED?  I would pass.
GMT+8, 2025-12-23 02:17 , Processed in 0.094225 second(s), 18 queries .
