CO2 Pressure when full
发表于 2021-9-1 00:14:12 | 显示全部楼层 |阅读模式
Just replaced my CL tank from local dealer and the pressure reads 1500psi on my meter. Dealer said it should be 2000 or 2200. They also said they had no meter for me to check it at store. Also suggested I should be using 15-20 psi on the output side. Is it time to find a different welding supply company?
Reply:The CO2 in your bottle is stored in a liquid form.Pressure will vary somewhat based on temperature.  Seldom will a full bottle of CO2 read 2000-2200 PSI even when full.The only way to accurately tell if you got a full bottle is to weigh it.  Compare the tare weight (empty) with the weight of the bottle received.Think you're talking about 20 CFH on the flow rate, not 20 PSI.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:I have seen anywhere from 1500-2200psi depending on temp in my shop (-30 unheated winter temps to 90+ this time of year)
Reply:Thanks for the info.....hated to think they were ripping me off.Should I try to use 20 cfh as opposed to the 25 I have been using
Reply:Originally Posted by VestigialCurly69Thanks for the info.....hated to think they were ripping me off.Should I try to use 20 cfh as opposed to the 25 I have been using
Reply:Originally Posted by ironmangqI have seen anywhere from 1500-2200psi depending on temp in my shop (-30 unheated winter temps to 90+ this time of year)
Reply:Pressure in a CO2 tank means nothing, can have a 20 pounder with one pound left in it at the same pressure as a full one.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by Oldiron2Maybe you missed that he was asking about CO2, according to the title. The vapor pressure for that is about 900 psi at ambient temperature (~25*C).
Reply:My CO2 bottles usually are around 650 or so when they still have liquid in them.
GMT+8, 2025-12-23 02:16 , Processed in 0.071945 second(s), 18 queries .
