Your best home made tools
发表于 2021-9-1 00:14:11 | 显示全部楼层 |阅读模式
Post your best home made tools or equipment. Here is one of my tube benders I built years ago, it has done a heap of work.BenderBent tubeIn PartsIn useSmall green bender. Large yellow benderSimonLabel EverythingMetal Fabrication - Welding Repairs - Wrought Iron - Sign Writing - Custom Decals.
Reply:I don't have a picture of my Home made tool.His, I mean its, name is Nathan. I molded it into the way I wanted him/it, this tool makes life more simple. Makes taking out the trash, very easy.*insert welding gibberish here*                    Mandy
Reply:The Problem With Nathan Tools Is They Grow Up And Move Away!!!!
Reply:Welder.man that is one great looking tool. Just love those home built ones. they last forever and if they break, you fix'em yourself I think one of the most used tools I've built and posted here was a home built tubing notcher. I use it a lot and it's worked perfectly.http://snagsblog.com/Forum/phpBB3/vi...php?f=34&t=786Miller 302 Trailblazer/Custom TrailerMillermatic 350P/Spool gunMillermatic 252Miller Spectrum 875Miller Dynasty200DxHypertherm Powermax 85Tracker CNC 4X8 Pro Table (Down Draft)Visit us @ www.specialtyrepairscustommods.com
Reply:I'm very much a novice wannabe weldor and fabricator, but this was the first thing i've made so far.  It's a "creeper" to put your tools on when your underneath a vehicle working.  You can push it aroudn with you while you roll around on your own creeper.  Just some angle iron for a frame, sheet metal for the tray, and casters I bought at home depot.  Painted if flat black and used truck bed liner on the tray.
Reply:Paul I remember your pipe notcher and it is still on my list to build one. It looks great.fluxcorekid I think that is a great idea, If I built one I will have to go off road rubber as I don't have much concrete around here to work on.SimonLabel EverythingMetal Fabrication - Welding Repairs - Wrought Iron - Sign Writing - Custom Decals.
Reply:Originally Posted by TEDTWOFEATHERSThe Problem With Nathan Tools Is They Grow Up And Move Away!!!!
Reply:neat bender - does it do round and square with the same wheel (die? )?Gotta get one of those creepy tool things here's mine http://weldingweb.com/vbb/showthread.php?t=25448A butterfly without wings, is just an ugly bug
Reply:Originally Posted by Magnetic Mechanicneat bender - does it do round and square with the same wheel (die? )?Gotta get one of those creepy tool things here's mine http://weldingweb.com/vbb/showthread.php?t=25448
Reply:Welder man, sweet bender, how'd you make your dies?  I'm looking to build a bender also, I really don't feel like shelling out a few hundred for the bender and more yet for the dies.- If you can jump across it you can weld it!  - anonymous old boilermaker
Reply:thefluxcorekid,That tool creeper would sure come in handy to hold a drain pan for oil changes.  I gotta have one of those.  Welderman, Your bender in now on my list, too.  Thanks for posting.Last edited by Weldordie; 12-21-2008 at 01:00 AM.
Reply:Motorized hacksaw, built over 30 years ago.  Still accurate after all those years. Attached Images
Reply:That motorized hacksaw is sweet.  I like the anti leg gouge rubber, lol.Miller Dynasty 200DX Tig Welder
Reply:Originally Posted by KangiWelder man, sweet bender, how'd you make your dies?  I'm looking to build a bender also, I really don't feel like shelling out a few hundred for the bender and more yet for the dies.
Reply:Heres a picket twister I built. Its kinda hacked together, and you'll notice that one of the legs is cut right above the motor .....Its been sitting for a while, as you can tell.....
Reply:Originally Posted by welder.manI turned the dies out of solid round bar for one bender, the other larger bender I cut three disks from plate the middle disk being larger than the other two.
Reply:does that hacksaw lift on the return stroke ?andhow well does the microswitch work for counting turns of the twister?insert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:Originally Posted by chenrydoes that hacksaw lift on the return stroke ?andhow well does the microswitch work for counting turns of the twister?
Reply:Pneumatic can crusher, Pizza cutter 316 stainless. Attached Images
Reply:Originally Posted by OMSPneumatic can crusher, Pizza cutter 316 stainless.
Reply:the switch on the picket twister limits it to one turn correct?  i like the twister.  i have one that is manual.  can you say big cheater bar?
GMT+8, 2025-12-23 02:21 , Processed in 0.097015 second(s), 18 queries .
