Look what I got for 20 bucks
发表于 2021-9-1 00:14:10 | 显示全部楼层 |阅读模式
I found this at Agrisupply. It is kinda like TSC except more better BIG and cheaper.  A walmart of farm stores if you will.It was on the "discount" table.It had 20.00 written on it.  I had to inquire about it to the manager to make sure there wasn't a mistake.  He saiid the price was correct because it was missing something.  Well I knew I had the stuff to build the part so....Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:not bad huh? Attached ImagesEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:$20?!  Don't you feel bad?btw, looks just like my HF unit.Last edited by duaneb55; 12-12-2008 at 09:28 PM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yeah,  real bad.  Not as bad as my back has been feeling lately before I bought it.It looks like HF and about every other auto part store display model.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Nice engine hoist. You got one hell of a deal btw I I got one from HF   that looks just like itCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Tractor Supply......Been dealin' with Atwoods over in Stillwater for over a decade.  Know the manager, sorta just by tradin' there.Was doin' a lot of fencing a few years back, and was goin' in there seems like everyday, and writin' a lot of checks for stuff.  Well, the Com Check thing kicked out a thing saying that they couldn't accept anymore checks from me because I had written over some kinda amount within a short period of time.  Bull****.Manager comes out, overrides the goddamn thing, and I was on my way.  That's small store dealin's.Y'all kin keep Tractor Supply, Wal Mart, and all the other big box stores.  Unless it's the only game in town, then I gotta keep my mouth shut."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Agri Supply isn't quite that way. No scanners.  Old steel check outs.  Bolts sold by the pound.  How many hundred pounds you want?  Discs and cultivator feet in bin boxes loose.   Top links and hitchpins stacked deep. Ag tires,   10,000 gallon tanks.  PVC.   Hay equipment, trailers,   Mowers,  Hand tools, ratchets from 1/4 to 1 inch.  Drill presses, compressors.  Trailer kits,   Tents,  A whole three tier shelf full of small engines.  Tack and supplies for all pets.  Entire side of one building full of hand tools. Sprayers.  Sprayer pumps.  Trashpumps.  Weed eaters, chainsaws.  Electrical. Paint.  Coveralls, 2 gallon GoJo's,  wiches,  pry bars,  chains,straps, Harrow axles, bearings, collars, PTO shafts of any kind.  Parts to make up PTO shafts of any kind.  Replacement parts for rotary cutters of about any make. Finishing mowers.  Boat trailer rollers.  Truck boxes.  Fuel tanks,  Camoflage netting.  Rebuild and repair parts for air compressors.  Jacks, Anvils, vises, Stainless Steel and cast Iron cookware.  Large muck buckets.  Pecan rollers, Bug traps,  and I am just getting started.  The local store is about the size of a large Lowe's, but a lot less formal.  When you walk down the aisles, you better look up to make sure the overstockdoesn't fall on you from 20 feet up.Turkey fryers of course for those who like their turkey done quickly!http://www.agrisupply.com/default.as...cd2=1229142504And this is only a small bit of what they have.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Ok I want one around here.Mack
Reply:You got a good deal on that one.  A few years ago I wanted one.  Priced them.  Heck, I can make one.  By the time it was said and done, I had more time and money in the thing than if I had just gone out and bought one.
Reply:We have something similar here in Canada called Princess Auto, they carry just about everything:www.princessauto.com Originally Posted by lugweldAgri Supply isn't quite that way. No scanners.  Old steel check outs.  Bolts sold by the pound.  How many hundred pounds you want?  Discs and cultivator feet in bin boxes loose.   Top links and hitchpins stacked deep. Ag tires,   10,000 gallon tanks.  PVC.   Hay equipment, trailers,   Mowers,  Hand tools, ratchets from 1/4 to 1 inch.  Drill presses, compressors.  Trailer kits,   Tents,  A whole three tier shelf full of small engines.  Tack and supplies for all pets.  Entire side of one building full of hand tools. Sprayers.  Sprayer pumps.  Trashpumps.  Weed eaters, chainsaws.  Electrical. Paint.  Coveralls, 2 gallon GoJo's,  wiches,  pry bars,  chains,straps, Harrow axles, bearings, collars, PTO shafts of any kind.  Parts to make up PTO shafts of any kind.  Replacement parts for rotary cutters of about any make. Finishing mowers.  Boat trailer rollers.  Truck boxes.  Fuel tanks,  Camoflage netting.  Rebuild and repair parts for air compressors.  Jacks, Anvils, vises, Stainless Steel and cast Iron cookware.  Large muck buckets.  Pecan rollers, Bug traps,  and I am just getting started.  The local store is about the size of a large Lowe's, but a lot less formal.  When you walk down the aisles, you better look up to make sure the overstockdoesn't fall on you from 20 feet up.Turkey fryers of course for those who like their turkey done quickly!http://www.agrisupply.com/default.as...cd2=1229142504And this is only a small bit of what they have.
Reply:I was so busy raggin' on the big retailers, I forgot to say NICE FIX on the cherrypicker.  Sorry"Any day above ground is a good day"http://www.farmersamm.com/
Reply:20 BUCKS! Wow thats a smokin deal. You had all the steel ya needed layin around?
Reply:Yeah,  I buy a little extra every time I do a job.  I figure it into my quotes, just in case... you never know when those pieces you measured and remeasured come up a little over the estimate, just enough to have to buy an extra 20 ft stick to get one 12 inch piece.  Every once in a while,  I can do a job with out ordering any metal at all.  Sometimes, I buy their dog eared pieces.  Right now Ihave 4 sheets of 18 ga.  4x8 sheets that cost me $10/ sheet because they had moisture settle on them.  The steel you see in the picture only cost me 256 bucks because they were set aside for scrap, because they were cut for an order that never went out.There's a welding trailer sitting in that pile, 2 saw mill track sections and probably enough left to build something nice.  I don't know what but something nice.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by dellwasWe have something similar here in Canada called Princess Auto, they carry just about everything:www.princessauto.com
Reply:Originally Posted by farmersammTractor Supply......Been dealin' with Atwoods over in Stillwater for over a decade.  Know the manager, sorta just by tradin' there.Was doin' a lot of fencing a few years back, and was goin' in there seems like everyday, and writin' a lot of checks for stuff.  Well, the Com Check thing kicked out a thing saying that they couldn't accept anymore checks from me because I had written over some kinda amount within a short period of time.  Bull****.Manager comes out, overrides the goddamn thing, and I was on my way.  That's small store dealin's. Y'all kin keep Tractor Supply, Wal Mart, and all the other big box stores.  Unless it's the only game in town, then I gotta keep my mouth shut.
Reply:No contest,  Agri Supply is at least 5 times bigger here. There store covers a couple of acres.  The outside equipment, pipe, tanks, sprayres and trailer area  covers 3 more.I used to work for the TN farmer's Coop. They have some of the best cooperative stores I have ever seen.  Organized little company. 600 million annual sales.  Best job I ever had, pay, benefits out the wazoo.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:We've got one a couple hours away in Greenville, NC and it is a very dangerous place to be with a credit card. They have a great selection of hitch accessories and I got my Dad a replacement seat for his JD 4040 while we were picking up our aluminum hitch hauler that we use on the beach for coolers and chairs.
Reply:Originally Posted by Rod StickWe've got one a couple hours away in Greenville, NC and it is a very dangerous place to be with a credit card. They have a great selection of hitch accessories and I got my Dad a replacement seat for his JD 4040 while we were picking up our aluminum hitch hauler that we use on the beach for coolers and chairs.
Reply:Lug Weld, I have bought a ton of stuff from MSI (agri-supply) there in Tifton over the years.  Back when I was in College at ABAC I bet we spent $200 a month in there on all kind of odds and ends.  What part of South GA are you located?I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:You know Grubbs then. I'm a swayback from Abac too.  I live in Fitzgerald now. Sorry for the slow reply.  Been in Mobile with the out-laws.  On pda.  Mrs. Lugweld and I are on way to b'bridge to see my Grandmama for the night.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Yep, I'm very familiar with Jimmy Grubbs.  I was an AET major, and his assistant the last two years I was there.  I even helped them teach the welding labs while I was going to school there.  ABAC is a much different place than it was when I was there.  What years were you there?  I'm actually doing some work over in the Fitzgerald area as we speak.  I'll be back over that way right after the first of the year. ~JacksonI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:cool deal.That's gotta be worth almost $20 for scrap!Don't talk about it, Just do it!
Reply:93-94. Transferred in.Transferred out to ag ed at uga.Whatcha working on?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Wow, that's an insane deal, NICE find!Have a Jeep Cherokee?  Click Here!
Reply:Nice, that was a steal.  The purdy blue expensive one I have from O'reilly's looks just like it.  Oh, and TSC sucks because if you need something that normally would be bought in pairs.... they usually only keep 1 in stock.  But they are the only ones around here that carry some of the junk I need.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. toolslittle fuzz.Try the CoOp stores.  Many of them can whip the TSC stores with one hand tied behind their back.  If they don't have it,  It will be on their doorsteps the next morning.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I transfered into ABAC in 97 after 3 years at UWG.  I had quite a good time being one of the few 21 year olds on campus.   We have a contract installing water meters on irrigation systems for Georgia Soil and Water.  I've got about 10 over in your area that I have to re-pipe and install the meters on.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
GMT+8, 2025-12-23 02:20 , Processed in 0.177979 second(s), 19 queries .
