So my craftsman belt/ disk sander only has one table that can be moved from the belt to the disk sander, but i hate having to switch them back and forth all the time. So i started making another table for the disk sander. Im going to later put wood for the top on it since the disk side is used alot for wood. So heres the sanderHeres the hole for the table to plug intoLuckly the hole is 5/8 and thats the only roundbar i had left On to the next post!!!!
Reply:Heres some large flat bar i had that i cut into two 2'' strips.But i said its too rusted! So the two pieces went into the electrosis bath for two days!! And now look at themStrip welded to the round barAnother pic of the weld. Used lincoln nr 211mp fluxcoreAnd finally put into the hole so see how it looksThis is as far as i got right now. Stay tuned for more progress
Reply:Ok i finished it todayTop piece welded Test fit Holes drilled to attach the wood On to the next post..
Reply:Finished with the wood put on topAlso i dadioed a gove in it for the miter guageFinished!!
Reply:Man, that was one rusted piece of metal Looks like some of the stuff I have layin' around hereThe welds look really good. And the top is cool how it's dadoed. Did you use a dado blade on a table saw, or a router?Spatter's the pits with the flux core ain't it?"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Sam,I used the table saw but i didn't feel like puttin in the whole dado blade setup, so i just nibbled away until the grove was right. Then i cleaned it up with the chisel.ThanksShane
Reply:Nice flux core welds Shane, damn! If you squint it looks like a TIG weld.
Reply:Thanks burnitYa gotta spend money to make money!
Reply:Originally Posted by BurnitNice flux core welds Shane, damn! If you squint it looks like a TIG weld.
Reply:nothin like thinkin somethin through and puttin it together..humdinger |
