查看: 17|回复: 0
How thick of the steel can be welded by the handheld laser welding machine?
管理员
Rank: 9Rank: 9Rank: 9
发表于 2021-6-10 16:49:04 | 显示全部楼层 |阅读模式
图文
图文封面:
The traditional welding process is difficult to ensure the laser welding quality and forming effect of sheet metal, and the laser welding technology just makes up for this determination. It has the incomparable characteristics of the traditional welding technology, and can well reduce the welding defect rate. In the laser welding technology industry, there are many manufacturers of stainless steel parts using laser welding technology. The laser welding effect of laser welding machine is obviously good, and laser welding technology is also a good choice for processing stainless steel, aluminum galvanized sheet and other metal materials. What thickness of carbon steel plate can laser welding machine weld?
Laser welding technology makes full use of high-energy laser pulse to heat materials locally in a small range. Let the energy transfer to the material, make the material melt to form a specific molten pool. It is a new type of welding technology, most of which are used for laser welding of thin-walled material precision instrument parts. It can realize spot welding, butt welding, overlap welding, seal welding, laser welding, etc., with small weld, small heat affected zone, no deformation, fast laser welding speed, smooth weld, high laser welding quality, stable and firm, precise welding precision control and high positioning precision, And it's easy to automate. With the continuous development of science and technology, the traditional welding methods can not meet the special requirements of materials in many industrial production technologies. The characteristics of laser welding machine are low bonding strength, fast welding speed, time-saving, labor-saving, labor-saving, labor-saving, labor-saving, and help enterprises reduce expenses. In particular, many industries have gradually replaced the traditional welding methods.
1. General Electric 1000W handheld laser welding machine
It can be used for the welding of various metals such as kitchen cabinet, outdoor cabinet, stair guardrail, anti-theft door and window, stainless steel plate, aluminum alloy, carbon steel, galvanized plate, etc. if the thickness of household appliances and high-speed stainless steel laser welding technology is less than 1 mm, the 1.5 mm carbon steel plate with the penetration less than 1 mm can be selected as 1000W laser welding machine
Generally speaking, the thickness of materials to be welded by 1000W laser welding machine is mostly less than 3mm, but in fact, thicker materials can be welded according to the strength and thermal deformation of materials, and even the thickness of 10mm can be welded. Generally speaking, the laser welding effect is the best when the thickness of materials to be welded is less than 3mm.
If the thickness of stainless steel plate is less than 3mm, laser welding should be carried out completely, and the more fine the better. In general, it is recommended to use 1000W fiber laser for laser welding. The welding speed is fast, the forming speed is fast, and the weld seam is smooth. The thickness range of laser welding technology is related to the characteristics of the material, including the material thickness, material and so on. The parameters of different materials are different. Guangdong Pudian laser welding machine is cost-effective. With years of experience in laser research and development of welding equipment, the technology of laser welding machine is mature, and the product performance is safe and stable. Guangdong Pudian laser power Co., Ltd. always adheres to the principle of customer first and provides customers with high-quality products and services.
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?立即注册
x
GMT+8, 2025-12-16 21:59 , Processed in 0.081754 second(s), 21 queries .
