Pipe formula
发表于 2021-9-1 00:14:04 | 显示全部楼层 |阅读模式
Was wondering if anyone knew a formula to calculate the gallons per foot for pipe. I have a bored well and was trying to figure out how much water was in the well. Its a 30" casing and i have 12' of water available.Thanks for the help..
Reply:Volume= pi R squared times height, or length.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:There's roughly 7 1/2 gallons per cu ft. I make the volume of the pipe at 4.9cf/ linear ft of pipe, so 59cf of water. So roughly 441 gallons if my math is right after a long day.Edit: fixed my math. Last edited by DSW; 06-20-2011 at 07:21 PM..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thanks for the answers , not as much water available as i was thinking.
Reply:you have to consider the well will also be replenishing itself at a certain rate as well so while you only have x amount available at the present time the well will be topping itself up constantly._______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:This formula is for a round tank, just pretend there is no ends for your situation.  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:The math is simpler for imperial (British) gallons. 1 cubic foot is 6.25 gallons
GMT+8, 2025-12-23 02:18 , Processed in 0.092058 second(s), 18 queries .
