unidentified arc welding electrodes
发表于 2021-9-1 00:14:04 | 显示全部楼层 |阅读模式
Hello to each and all.  I've been given a handful - 20+ - of Satinex arc electrodes, 2.5 mm, no codes marked. They're turquoise blue-green in colour. This is all the info I'm able to give - it's all I've got. Would be very grateful for any clues as to what I'm looking at. Many thanks.
Reply:A quick goggle search turned up the following links.http://www.murexwelding.co.uk/murex/...-NEW-GREEN.cfmhttp://www.machinebuilding.net/p/p2659.htmSeemed to be a lot of info... try searching the web.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Sounds like stainless steel rodsLincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:If they can't be POSITIVELY identified, they are either practice or scrap."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2025-12-23 02:16 , Processed in 0.095045 second(s), 18 queries .
