查看: 13|回复: 0
weld on barrel hinges
发表于 2021-9-1 00:14:03 | 显示全部楼层 |阅读模式
i need to build some shed doors and was gonna try some barrel hinges i have never used them before always used bat wings or straight round style with the pin. never the round to bevel style. since ive never used them and searched and cant find any info. want to make sure there installed correctly. is the best way to install these with the beveled v section against the post and welded on both sides >I ???350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:There may be some good discussion in some of the ' gate ' threads lately...Weldandpower Lincoln 225 AC,DC with Briggs 16hp gas engine.WW2 era Miller TIG.
Reply:That's how I usually do those. One v to the post, the other to the door/gate. Leave a little space so they don't rub.Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
GMT+8, 2025-12-23 02:19 , Processed in 0.090162 second(s), 18 queries .
