Here is a recent job i just completed
发表于 2021-9-1 00:14:00 | 显示全部楼层 |阅读模式
this is a hydraulic power unit i built.  It runs a 30yd self-contained compactor.  I build them alot. the second picture is the compactor it-self Attached Images
Reply:Good job did you design the unit yourself?Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Looks like a dunking booth.  I guess you get dunked then crushed.  Well any way, nice, clean job. Paint is always the consumate touch to any project.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:yes i designed it.  Almost all the units i build are one offs. I deal alot with hydraulics and fabrication.
Reply:that looks very simular to one in the back of a place I worked for.  They are great for crushing evidence from home. Common sense in an uncommon degree is what the world calls wisdom.
Reply:That's clean looking work.  Schedule 40 hinges on dock plate?"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Trash compactor?  I've repaired many over the years. Nice looking fab job.
Reply:Fine Job on the Compactor!John
GMT+8, 2025-12-23 02:17 , Processed in 0.101253 second(s), 18 queries .
