Sizing Material
发表于 2021-9-1 00:13:59 | 显示全部楼层 |阅读模式
I am building a "brew sculpture" as shown in the picture below.   The top tank will weigh a maximum of 125 lbs,the middle section on mine will have a picnic cooler with a maximum weight of 50 lbs and the bottom or lowest section will have a maximum of 80 lbs.   I have access to 1 1/4" x 1/8" angle iron.  Assuming I did a good job of welding, would this size angle iron be suitable for this cart.   BTW, it will be moved 5-6 feet forward and back once or twice a month and only when the tanks are empty.
Reply:Somebody on here made some really nice micro brew racks.  I can't remember who.  I think there was a big discussion about the weight of water in the thread.  (I was wrong as usual)"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Water weighs roughly 8 1/2 lbs per gallon.   Mine is a "5gallon" system but the upper tank will typically have 10 gallons in it when brewing and the lower tank about 8 gallons.
GMT+8, 2025-12-23 02:18 , Processed in 0.079235 second(s), 18 queries .
