My first hand rail
发表于 2021-9-1 00:13:58 | 显示全部楼层 |阅读模式
These stairs will not see much use but they still need a hand rail.I'm normally a wood guy but they have seen my welds and let me do this.plum and straight right?I used my hd 180 with flux core .035 wire.The hand rail is like 18ga so welder set at A and 1.5 wire speedThen they wanted some steel posts under it.I didn't have a torch with me so I tried a steel cutting blade...sweet I may never use a torch againBolted the plates top and bottomSlipped in the 4" steel post (1 was very tight reason for the big hammer)Weld it up.... welder on E and around 3.5 wire speed [ //img145.imageshack.us/img145/2971/handrailpainted002dp6.jpg[/IMG]Last edited by IamVince; 01-09-2009 at 07:41 PM.
Reply:Posts completed Not too bad for a home hobby welder
Reply:Nice for #1 they get easier after this, and faster too. Keep up the good work.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:The rail turned out good and straight.Is there any concern about the mud work on this job?  The steps are poured on fill, and don't seem to have any kind of footer along the length of the steps.  That piled up stuff supporting the steps is gonna move over time given the the steep angle, and hilly conditions.  Seems like a washout waitin' to happen.  Not a lot of substantial support there.  Ok, I'm gettin' picky"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I was thinking along the lines of farmersamm,, I can sure see the need for the rail!!  Looking at the pictures I think I'd even put in some steel mesh all along it for the kiddies and doggies!!  thats a steepslope off to the side there,, I hope they are going to put in more substance along the ground??
Reply:Nice work IamVince.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by farmersammThe rail turned out good and straight.Is there any concern about the mud work on this job?  The steps are poured on fill, and don't seem to have any kind of footer along the length of the steps.  That piled up stuff supporting the steps is gonna move over time given the the steep angle, and hilly conditions.  Seems like a washout waitin' to happen.  Not a lot of substantial support there.  Ok, I'm gettin' picky
Reply:Originally Posted by IamVinceI'm not a cement guy but I believe the bottom section was made just like the top then they shoved some loose dirt under it.I bet the stairs will get a locked gate since its a office building and they lead to a transformer and generator.Shouldn't be any kids down there.Rains everyday here doesn't seem to be washing away yet.
Reply:Originally Posted by farmersammMight be that the bottom edge of the stair stringer is reinforced inside the pour, and totally self supporting.  But it was something that caught my eye.Sorry to have crapped on the thread.  The rail looks really nice
Reply:looks goodLincoln 255XT Power Mig        Lincoln Precision Tig 225Hypertherm Powermax 30
Reply:Looks great!!!! I enjoy handrail when there done. That makes it even tougher when you do it in the field.Keep up the good work.WTW9Y GeorgiaAnnamel TW9Y Georgia
GMT+8, 2025-12-23 02:17 , Processed in 0.074022 second(s), 18 queries .
