Ok..My turn for the "bonehead play of the day!!" Today i did exactly what i had told my first class to watch out for.. Always be aware of where things are at all times..Like the chair legand the torch hoses..see where i'm going here?I went thru the procedure as i always do.."gas on?"..check"water on?"..check"water flowing?..check(i have a clear tube for the water exhaust so i can see that its flowing when i hit the pedal)ok all's good lets weld..300 amps..D.C."Hmmm" i said under my mask.."i need to move over about a foot..."well i did and promptly put the stool leg right on the water tube..1 pass later i knew "that smell" this thing burned up SO FAST...i was kiking myself in the keester right away..Wog802 was down front and could smell it too Jeesh!!!Just goes to show you that one must be aware at all times..but i did salvage one part..this is still good..so if i run the torch body over at least i have a spare..oh well crap happens... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:If you're gonna do something, do it right. Looks like you did a good job burning it up. LOLOnly two defining forces have ever offered to die for you, Jesus Christ and the American G. I. One died for your soul, the other for your freedom.
Reply:zap look at it like this even monkey's fall out of trees once in a wile ChuckASME Pressure Vessel welder
Reply:Aw, heck, Zapster....a little duct tape should fix that....OK, maybe a LOT of duct tape.
Reply:i see you had visit from MR. MURPHYmurphy's law now thats a bum deal ZAP
Reply:aww man i liked that torch haha. looks like you did it right at least, 300 amps!! woohoo
Reply:Good one!How did you come across the nickname ZAP? Sort of a similar thing occurs when you forget to connect your ground lead to the portable turntable. The welding current has nowhere to go but up the 110V cord that powers the turntable! Not too serious, just smokes the cord.
Reply:How did you come across the nickname ZAP?
Reply:I was thinking about selling or trading my extra 250 torch like that one, but now I realize I could easily do the same thing as this. Gotta keep the spare...
Reply:If we never made any mistakes, we wouldn't learn anything!
Reply:Doh!Drivesector Hobart Handler 140Hobart Handler 180Ready Welder 2Hobart Air Force 400Airco Stinger 225Of all the things I've lost, I miss my mind the most."OZZY"
Reply:Originally Posted by zapsterOk..My turn for the "bonehead play of the day!!" Today i did exactly what i had told my first class to watch out for.. Always be aware of where things are at all times..Like the chair legand the torch hoses..see where i'm going here?I went thru the procedure as i always do.."gas on?"..check"water on?"..check"water flowing?..check(i have a clear tube for the water exhaust so i can see that its flowing when i hit the pedal)ok all's good lets weld..300 amps..D.C."Hmmm" i said under my mask.."i need to move over about a foot..."well i did and promptly put the stool leg right on the water tube..1 pass later i knew "that smell" this thing burned up SO FAST...i was kiking myself in the keester right away..Wog802 was down front and could smell it too Jeesh!!!Just goes to show you that one must be aware at all times..but i did salvage one part..this is still good..so if i run the torch body over at least i have a spare..oh well crap happens... ...zap!
Reply:Thing like that tend to happen on a saturday when it's gotta get done today. My assistant wonders why I have 2 of most everything.Tough as nails and damn near as smart
Reply:Zapster:Is this what you dragster guys call a "burn out".Sorry about the torch, things like that really suck.I know your pain.Sign on East Texas payphone: Calls to God 40 cents......it's a local call... |
