Lincoln 225 Tig
发表于 2021-9-1 00:13:55 | 显示全部楼层 |阅读模式
Is this the deal or am I missing something?http://cgi.ebay.com/LINCOLN-PRECISIO...QQcmdZViewItemThe welding shop near my house had a 185 lincoln tig for a little over $2000 so when I saw this I wondered if being a newbie I am missing something important.
Reply:i'd just continue the search for a real watercooled machine..if your going to concentrate on aluminum watercooled all the way.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Aluminum only occasionally.  Mostly steel.  (A man's material)
Reply:IOC is a solid company.  I would have no problem bidding on this one.  You can bypass e-bay and buy direct by calling IOC.  You will save a few $ dollars off there buy it now price.  For a few $ more you can get Thermal Arc Arcmaster 185 if you want an inverter.  I was not impressed with Lincolns torch.  ( The woven cloth covering snag and gets torn up pretty easy.  The pulser on the Lincoln only sets the pulse rate. )The Thermal has a full function pulser but the Lincoln wins in the output amps.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:Originally Posted by wojeepsterIs this the deal or am I missing something?http://cgi.ebay.com/LINCOLN-PRECISIO...QQcmdZViewItemThe welding shop near my house had a 185 lincoln tig for a little over $2000 so when I saw this I wondered if being a newbie I am missing something important.
Reply:I got scared off of lincolns because they do not want to repair machines that are out of warranty (I read this in another post on page 9)  I found an Thermal Arc Arcmaster 185  that I have ordered.  Everyone seems to be positive about that one.  More than I wanted to pay but then most things worth having are.......Thermal Arc 185 TigHTP 200 MigCraftsman O/A1942 Bridgeport Mill12 Ton Hyd PressConsew Walking Foot
GMT+8, 2025-12-23 02:17 , Processed in 0.093259 second(s), 18 queries .
