vertical welding with O/A
发表于 2021-9-1 00:13:55 | 显示全部楼层 |阅读模式
Is this even possible?  Well I know it is, but usually about an inch or so into the bead, the puddle does the exit stage down move and I end up with quite a depression in the joint.  Should I be going at it from bottom up?
Reply:I do it vertical down.You know you're getting full penetration because you can't really move until your pool is molten.Make sure you have the tip angled up at like 15* from perpendicular.
Reply:It certainly is possibe, I found it easier that flat. Go for the bottom up and the metal is pre-headed for you as the heat rises
Reply:O/A welds the same in all positions, it's really easy.
GMT+8, 2025-12-23 02:15 , Processed in 0.074270 second(s), 18 queries .
