Help finding aluminum elbow
发表于 2021-9-1 00:13:53 | 显示全部楼层 |阅读模式
I'm hoping that somebody here can help me find some aluminum short radius elbows. Something like the copper solder joints used in plumbing would be perfect size if only i could find them in aluminum. Like this I need one to weld a new lower oulet onto my aluminum radiator in my car. I have asked around other places and done a fair share of searching with no luck.  What i want to do is move the oulet to the left about 6 or 7 inches toward the red coupling on the left side of this picture..  If nothing else, I will use a straight section of tubing like what is on there already but i would much rather have an elbow if such a thing exists. Thanks for any help!Edit: Forgot to mention I need the inlet/outlet to be either 1.5" or 1.75"  either will work just fine.
Reply:Here.http://focus.c-f-m.com/spaturbo90deg...FQbe4Aod8F5XNA...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Unfortunately the smallest size they offer is 2"  which seems to be the problem I keep running into while searching. I need a 1.5" or 1.75" both will work.
Reply:Try IMS, http://www.industrialmetalsupply.com/  their burbank showroom has a lot of stuff like that as they cater to the movie and TV industry.   I drool every time I go in thereTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Try these guyshttp://www.wagnercompanies.com/site/...icle&rpid=1177http://www.mcmaster.com/Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I use this site for stuff, not that smal, but they may have itwww.intakehoses.com
Reply:Now I found it..http://www.cxracing.com/mm5/merchant...ry_Code=PIP150Just give me time and I WILL find it....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Thanks for all of the links, guys!  I just ordered the 1.5" 90 degree L bend from the link Zap posted. Its not quite what I was initially looking for but after taking another look under the hood I think with a little bit of trimming it will work out just fine.  I'm sure I'll be back to post up some pics of my ugly aluminum welds
Reply:For something like a radiator where nice round flowing elbows aren't crucial I have taken pipe and cut it at a 45 degree angle and turn them 180 of each other makes you a 90. Weld it up and onto the pipe or radiator. Doesn't look fabulous but if it is in unseen area it is sometimes acceptable.
GMT+8, 2025-12-23 02:19 , Processed in 0.090693 second(s), 18 queries .
