Need Cutter Recommendation. Thanks.
发表于 2021-9-1 00:13:52 | 显示全部楼层 |阅读模式
Hello--I am very inexperienced in metal-cutting and am looking to purchase a cutter to use at home to cut brass & wood to start--possibly other materials eventually. The materials I'm cutting would be mostly approx 1-2mm thick, up to maybe 1cm. I would be cutting various shapes, including outlines of countries, from about 3/4" tall and up.For example:Please advise. If I need to provide any other information please let me know.Thanks very muchGabe
Reply:Looks like a job for a bandsaw with a selection blades.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:It would help if you could edit your post (the button is near the bottom right, and works for something over an hour, IIRC) and resize your photo so the text isn't cut off. It first gives a 'simple" edit window; then click the 'advanced' button and next the 'attachment button, finally remove the one shot, resize it and repost its new version.As for cutting small concave pockets like that, I'd guess a "nibbler", either air or electric powered, would be the best bet. Or, if you have lots of similar parts to make, a die set and a press to use as a punch. The parts look fairly small without a reference in the picture; how large are they?Edit:   Guess that's your hand in the picture; yes, a very fine bandsaw or jig saw would also do.
Reply:Dang sorry about that--I didn't get back to the post in time, but here is the full text...thanks to everyone for their thoughts:I am very inexperienced in metal-cutting and am looking to purchase a cutter to use at home to cut brass & wood to start--possibly other materials eventually. The materials I'm cutting would be mostly approx 1-2mm thick, up to maybe 1cm. I would be cutting various shapes, including outlines of countries, from about 3/4" tall and up.
GMT+8, 2025-12-23 02:16 , Processed in 0.092682 second(s), 18 queries .
