fluxcore welding question
发表于 2021-9-1 00:13:52 | 显示全部楼层 |阅读模式
For the life of me a cannot seem to remember the  series of fluxcore wire made by Lincoln that I used to reweld heavy equipment years ago that had very high deposition rate and great wetting properties and could be used for all postion welds. This wire produced a slag that curled off most times and if not you just brushed your chipping hammer over it and it would easily come off.I would appreciate help with this if anyone can help, could it have even been metalcore? I hope that my explanation helps me  with the answer.
Reply:Try the Licoln site, you might recognize the wire by number or description.http://www.lincolnelectric.com/en-us...-shielded.aspxRick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:I checked the site before asking on welding web and i cannot remember the number.
Reply:Was it Innershield, or Dual Shield wire? If it was Dual Shield it was probably the Elite 71 or something of the same class.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I've used NR-203 Nickel to repair cracks in excavator buckets before.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Innershield wire.
Reply:It was innersheild and it worked awesome in spray transfer mode for repairing and building in poor fitting parts in heavy plate and heavier material.
GMT+8, 2025-12-23 02:15 , Processed in 0.093360 second(s), 18 queries .
