Craftsman AC 180 Amp Portable Arc welder
发表于 2021-9-1 00:13:51 | 显示全部楼层 |阅读模式
My younger brother is looking at a Craftsman portable arc welder that a friend is offering to sell for 60 bucks. He isn't really into welding a whole lot, and he is 13 years old, but I figured it could be a good welder for him to learn on, as well as maybe make a few cool projects. I could teach him the basics, and everything else is mainly practice. Does anyone have any experience with these things? I would imagine it uses a 220 cord, even though it is lower power. The smaller size, and portability would be good for my brother, I think.He says it's 230 volt/ 37 amps/ 60 cycles/ and single phase. I can see on the machine though that is says 180 amps, so I'm not sure what the deal is what that. We are just curious, and are not completely sure about what we want to do here.He is not sure if he will like welding, so I figure 60 bucks is a nice noncommital price too, so if he decides he doesn't like it, he hasn't lost too much...
Reply:Originally Posted by LantzHe says it's 230 volt/ 37 amps/ 60 cycles/ and single phase. I can see on the machine though that is says 180 amps, so I'm not sure what the deal is what that.
Reply:It says its a limited input AC  welder.
Reply:Anyone got any more info on this thing?
Reply:Welders of this type were used on rural power lines,Pole transformers were small so welders were designed that drew a maximum of 37.5 amperes.Many small towns did not have electric service as late as 1945 here.Lincoln Electric developed the 180 amp welder that could be used on a rural line without dimming lights of other customers on the line.Most have power factor capacitors that help small welders put out 180 amps.They were usually wound with copper wire.Sear Roebuck was very active in welding supplies even before 1940.
Reply:If it welds it is good; had I been offered a deal like that I would have probably purchased it.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:This site has a serious problem with spammers...
Reply:Originally Posted by LantzThis site has a serious problem with spammers...
Reply:limited input AC welder.
GMT+8, 2025-12-23 02:16 , Processed in 0.089391 second(s), 18 queries .
