Traveling welder
发表于 2021-9-1 00:13:50 | 显示全部楼层 |阅读模式
So i got a job out of state and the company want to fly me out to them. I was wandering i have a brand new welding hood and i gotta take it with me. Can I take it on the airplane?
Reply:I am sure you can.  Skis, fishing poles, golf clubs and bicycles all travel by air; be sure it is well packed and labled.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:Try just wearing it when you board. What could go wrong?Two turn tables and a microphone.
Reply:First time flying eh?Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:It'll fly just as well as you do.  Just make sure you don't have any tools that are over a certain length or that look dangerous if you happen to make your tool bag a carry on.  Don't ask how I know."The man of great wealth owes a peculiar obligation to the State, because he derives special advantages from the mere existence of government."  Teddy RooseveltAmerican by birth, Union by choice!  Boilermakers # 60America is a Union.
Reply:There is a maximum size for a carry on, you can look up the rules on the airline web site.   The carry on has to fit under the seat.  You may have to check a bag anyway, but the company should pay for that, usually around $25 each way.As was mentioned, pack it carefully if you are going to check it.  I would certainly put some padding (clothes) around the lens.If I think that the airline or TSA is going to be uptight about anything, I just put it in a checked bag.  One time I managed to avoid leaving behind some liquor by checking the bag I usually carry on, per the suggestion of a helpful TSA employee.  (Yes, there are helpful TSA employees).RichardSculptures in copper and other metalshttp://www.fergusonsculpture.comSyncrowave 200 Millermatic 211Readywelder spoolgunHypertherm 600 plasma cutterThermal Arc GMS300 Victor OA torchHomemade Blacksmith propane forge
Reply:Originally Posted by PangeaTry just wearing it when you board. What could go wrong?
Reply:Originally Posted by WeldingMachineIt's a religious headpiece ma'am
Reply:i was flying to florida to inspect some airhandlers. i had a 5/16 nut driver and a 4" channellocks in a bellypack. they confiscated it and said it could be used to disassemble an airplane.........good luck
Reply:Originally Posted by weldbeadi was flying to florida to inspect some airhandlers. i had a 5/16 nut driver and a 4" channellocks in a bellypack. they confiscated it and said it could be used to disassemble an airplane.........good luck
Reply:Spud wrench?They will let a welding hood on, but not 6 oz of shampoo thats our gov for ya!Learning one rod at a time
Reply:Do yourself a favor, put it in a checked bag. We fly all the time with all kinds of tools, some of them are used for electrical troubleshooting and some for woodworking and welding including hoods, gloves, leathers etc. Go ahead and try to figure that mix out? Anyway, after hours of messing with TSA inspectors trying to explain what it is and what it does, checking it just saves the hassle. Most inspectors are pretty slow and when something unfamiliar shows up it just locks them up. When you check your stuff you'll end up with a little card that says they went through your luggage. (I keep the ones they've issued and leave the stack on top, just letting them know I expect them to open it)Just remember to pack with plenty of padding. Baggage handlers only know how to throw and kick.Trailblazer 302G12VS Extreme Miller SD180Coolmate 4Miller 251Miller 175Victor OAHypertherm 380Milling MachineLatheBandsaw
GMT+8, 2025-12-23 02:15 , Processed in 0.104377 second(s), 18 queries .
