A full belly...pan
发表于 2021-9-1 00:13:48 | 显示全部楼层 |阅读模式
Here is a project that I am working on.  Should be through tomorrow.  Forgot the camera yesterday so the pics start a little after the beginning.  Some of you may remember the Limb cage that I bid on...this is from the same dealer.  He called needing a belly pan for a tractor he had just sold.  The customer jabbed a stick through the oil filter into his radiator. The teats on the tires aren't even rubbed off good yet.  They just fixed it and I am putting it on.  Plate is 3/8" x5'x10'.The rough cut notch is for the tire to make a full turn.  It has a lot of oscillation and swings  greatly.  You can see the indention on the gray part of the engine cover that they have to accomodate the tuning of the wheel and pivoting of the axle.  It was necessary  to notch, because the engine needs as much protection as possible.  You can se the filter in the first photo that was knocked off. Attached ImagesLast edited by lugweld; 01-15-2009 at 10:09 PM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Here are some more.  You can see the loader control valve is a sitting duck for anything to wipe it out.  behind that is a hydraulic filter, a mass of wires, hydraulic lines, and several delicate solenoids.  Kubotas are quality built tractors,  but their design and engineering are as bad as they come.  Serious farmers won't use them because of all the claptrap and stuff literally hanging off the tractors , begging to be knocked off, with some scant little 18 gauge sheet metal gaurds barely protecting vital systems.  The close ups are of the front plate that mounts to the front of the tractor, slanting down and is welded to the belly pan to protect the front of the tractor. Attached ImagesEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:last pic for today. Attached ImagesEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:How will it be attachedWhat are the provisions for changing oil, front end lube, etc.That's gotta be one heavy Motha"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammHow will it be attachedWhat are the provisions for changing oil, front end lube, etc.That's gotta be one heavy Motha
Reply:Ok, same questions"Any day above ground is a good day"http://www.farmersamm.com/
Reply:The full plate weighs about 750 pounds. Trimmed up, I guess more like 400.There are three drain plugs.  One for the transmission/rear end, and two for the engine(it has a deep U shaped oil pan for the front drive shaft to attatch to).  A small hole will suffice for each, no more than 3" in diameter, enough space for a socket and fingertips to operate in.  All filters are mounted on the side, and above the pan.  Zerks are pointing straight out so nothing is covered up.I finished the most of the attatchment points  in the dark tonight.  But the last pics are the front attatchment, bolting up where the brush gaurd/ weight bracket will go.  The others will bolt to the engine frame and will share in common the loader to tractor mounts.  The outermost mount will actually be to the loader itself for support.If you look at the pics,  you can see little yellow lines.  These are the places for the attatchment points to be welded.  Above them are the bolts where they will be attatched. Most should be visible if you get out your cheaters.Last edited by lugweld; 01-15-2009 at 10:36 PM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I see the yellow lines now!!Sounds like the oil pan is like the one on  Mom's old 89 Crown Vic.  302 V8.  Had 2 drain plugs, front, and back with a sorta horseshoe thing in the pan to fit around the axle, or crossmember, or some damn thing.Is there a way to enlarge the holes under the drain plugs.  That damn oil has a mind of its own when you first open the plug.  Sometimes it goes as much as 6" out of plumb when it first starts comin' out.  That sh#t might be runnin' all across the belly pan, and over the side somewheres."Any day above ground is a good day"http://www.farmersamm.com/
Reply:If I remember right,the drain plugs on these tractors extend down sort of like a funnel to the plug and seem to drain well.  I think everything will be alright, but the plugs will only be an inch or so from the opening of the hole.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Sounds like it ought to work.Crazy thing about this computer crap.  Ya got people thousands of miles away from each other second guessing other peoples work.Aw Hell, good way to kill an evening"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Lot more fun to get a bunch of friends over, drink ungodly amounts of beers, and shoot the sh%t.Pissin' on the project ain't allowed, ceptin' for the dog"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Well the good thing about this kind of communication,  no matter how many beers or other beverages are drunk between friends, no one goes home with a black eye.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Wow, some of that stuff looks like it was put there to be ripped off. Down time is time folks just don't always have. It's gotta have a plate but plates can be dust and trash catchers too. Good work.
Reply:Never had a black eye in my life, thank you very muchI run too goddamn fast!!!!!"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Me neither, oh wait, I did get a cut above my eye once. We were throwing rocks on the playground at each other in the 4th grade.  Stayed out of trouble since.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Sandy, That is a problem that is common with Kubota.  No one designs the tractors from an experienced point of view.  It must all be done on computers.  I doubt if the designers could actually even get one of these beasts into gear.  The shifter is on the left down below the seat.  It really is a range selector. It has a clutch pedal, but it is a hydrostat.  The forward reverse pedal is tied into the throttle so when you hit the forward or reverse rocker pedal, it automatically increases engine rpm.  It does have a override though, just down and just out of reach on the right.  The rpm lever is set up like a lawnmower on the dash  I could go on and on about the poor designs. It is hard to believe the quality that goes into everything and then you see the design.  They are paradoxical.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Good philosophy on lifeI'd rather be hittin' it, than be gettin' hit"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice work, big stuff.  It will do the job.    And if the guy gets stuck, he can hook the chain to the bellypan to pull it out!David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Well, maybe I was asleep,but I have to ask whatever came of the cab guard project?   I agree w/ ya, I don't see how they can build such a good tractor and have so much vitals exposed to the vagaries of "workin' in the brush". When ya build a 4wd tractor ya gotta figure it's gonna go places other than a flat field or mowin' the grass on some suburban estate!!!  Good job, Lug. The owner will have to be creative to tear that off, however, always remember it's hard to make anything "idiot proof"!!!                       MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Made progress today.  Need to remount for final fit and drill and tap holes for access plates to the drain plug so they can be screwed back into place on Monday.  Too cold for the paint to dry. Notice in the last pic on this  post, the "junk" hanging off the tractor and particularly the filter placement is inches in front of the wheel and extends out into the track of the wheel area. Attached ImagesEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Here are some of the pics after I removed for painting.  I had some industrial enamel I mixed up for another project, completely unrelated to this one, which I hadn't painted yet.  I knew I had enough paint for both so I used it to save money.  The dealer said any dark color was fine, particularly black. I had this paint custom mixed for direct to metal industrial paint from Sherwin Williams.  At the time I had played with the color for the other project until I came up with this custom mix.  When I opened the can again today,  it hit me dead square between the eyes...It WAS KUBOTA GREY!!!!  An EXACT match!!!  Besides finding what a poor job I did on cleaning out my spray gun from the last time I used it, the day went well.  Final post Monday I hope... Attached ImagesEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:looks like a real life size rc 10, I dig it"Obstacles are those frightful things you see when you take your eyes off your goal"   -Henry Ford
Reply:Wow, that's big. Cityslicker here.  But smart enough to know that's no place for a filter. Thanks for pointing it out.So, how do you get it back under the tractor, drive over it? Or will it 'wiggle fit'? Last edited by Craig in Denver; 01-17-2009 at 12:32 AM.Reason: Can't spell9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:Looks pretty good!! Will the froont grill guard still bolt on??Theres only one other thing I would do, trim that sharp edge off of the mounting tab. If he hits something like a stump and the pan shifts a little it will cut a hole in the filter.see post 20 5th pic.     G3miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:Thanks for the suggestion G3, but the way the particular tab is fixed,  there can be no movement forward.  The only way it will shift will be a catastrophic event great enough to break the tractor in half, which in this case I don't care about the filter.  But if you examine post 21    pic 3  you will see  in the far left, mid part of the picture between the forks, I believe, I welded a "shield" to protect the filter from any debris coming over the tire or any thing that might wedge itself in there between the tire and the filter.Yes, the front grill gaurd will still bolt on. In fact, it will take less than ten minutes to take this pan on and off.  The only alteration that has to be done to any part of the tractor is the mounting brackets have to have longer bolts to accomodate the 3/8" plate.Last edited by lugweld; 01-17-2009 at 11:00 AM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXTCraig, you simply drive over it.  The front tabs are the closest set to the front tires.  IF you thread the wheels just right, the tabs barely "rub" the insides of the front tires.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Kubota's are painted orange so that trees and stumps can see them coming from a ways off and get ready to rip something important off.Nice job Lubweld.Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
Reply:All my life,  I spent trying to get people to spell my name right.  4 letters that all there is to it.  Now I shorten it and I get Lubweld?...lol  No insult taken.   I guess I have to just live with it... Stampeter...:drinkupbtw thanks for the compliment...Last edited by lugweld; 01-17-2009 at 12:38 PM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Nice work Lugweld.I don't know what the protection goal is, but I'll mention that  some pans even cap the service points with flush fitting plates and recessed bolt heads. Some pans use larger separate access plates, which are dropped for maintenance.As seen in post#20 picture #2; I wonder if the skid plate's protruding points near the tractor's step should be trimmed and/or capped? The problem is that the protruding points could cause a high stress point, which could lead to the door glass spontaneously cracking  or breaking out completely... depending how deep the plate stabbed into the operator's shin Good LuckLast edited by denrep; 01-17-2009 at 12:58 PM.
Reply:Originally Posted by lugweldCraig, you simply drive over it.  The front tabs are the closest set to the front tires.  IF you thread the wheels just right, the tabs barely "rub" the insides of the front tires.
Reply:Denrep,  Yes the holes will be capped so a stick doesn't work its way up to the vitals through the hole. Its unlikely it would but Mr. Murphy always hangs around tractor dealerships and follows their customers home. He already has enacted his legislative powers upon this machine to a nice taxing sum.  If you look at post 21 pics 4 and 5, you can see two painted plugs laying on the floor.  These will be attatched to two holes drilled and tapped on either side of the main hole via a piece of flat bar welded to the back with matching holes for the screws.As far as the cab door cracking, It "floats completely inside of a rubber trim piece.  Additionally, the cab is independent of the frame and is rubber mounted to isolate it further.  All points on the pan are connected to "hard" points on the frame or pieces that attatch directly to the frame.Craig, loader to which the outer most mounting tabs are connected must "fit inside of the wheels due to the quick detatch nature of this loader.  The loader actually detatches quickly by a pull of a pin or two and by releasing of the hydraulic couplings.  The operator then drives out from it or in to int depending whether it is on or off.  The loader base barely raises off the mounting posts when this happens,   The dimensions are roughly the same as the mounting tabs on the pan.  To sum it up,  it was by design, but had an element of "lets see if this works the way it should." to it when I backed the tractor off.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Denrep, After rereading your post,  I see the tongue in cheek nature of it.  Didn't mean to get all techinical on ya.  But agreed.  It may become a source of pain, but it sits only 12.5 inches off the ground, so it becomes a step in and of itself.  The same could be said of the step sticking out.  I have known my shin or knee cap to contact a tractor step...quickly followed by rolling around on the ground holding the affected spot and screaming in an unknown language.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Wow, i agree very nice work lugweld!!!!!!Ya gotta spend money to make money!
Reply:Originally Posted by lugweld...It may become a source of pain, but it sits only 12.5 inches off the ground, so it becomes a step in and of itself.  The same could be said of the step sticking out....
Reply:Denrep,The customer stated he wanted that part of the tractor protected so he wouldn't wipe out his step on a stump, which commonly happens in these parts.    Customer wants, Customer gets.  I think a little South GA sand naturally incorporated into the paint might be all he needs.  Our mud isn't slick, It is gritty.I do have a little expanded metal I could tack down...Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:The standards, pylons, brackets, ATTACHMENT THINGYS!!!! turned out absolutely vertical and square.  That must have been a good feeling  I always feel good when attachment points turn out really good.  The photo shows that you did a really good job.Next time you do one of these, think about the tractor high centering, the plate being hit really hard from the side, and the plate under the entry steps getting bent upwards  It'll drive ya nuts."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Samm, that tractor barely has enough power  to pull it self and weight to keep it in contact with the ground.lol.  The plate is thicker than the transmission housing.But if it bends,  it just means I charge the guy more to fix it.  If he is that careless, methinks he will be needing a whole 'nother tractor.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Lugweld... I'm goin' on a diet.  I'm finally tryin' to figure out how to build something as strong with less metal.  I'm goin' GREENThickness ain't Godlieness.  Along the wide portion of the plate under the steps, it could bend.  A couple of one inch spines would convert it into something Arnold couldn't bendI'm thinkin' that you coulda dropped down to 3/16 plate, with well placed stiffeners, and it would have been just as stout, if not more so.Don't get yer boxers in a bunch.  I think it's a good thing to kick around for S&G's"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Samm.1/4 was considered with more reinforcements.However,  when I saw so many wires, hanging out, I started thinking about all the trash and garbage those gussets would trap and hold.  Mix in a little grease, oil and decomposing organic matter, you have a recipe for a fiery end to a little orange tractor. and possibly its operator.The customer wanted something clean and easy to maintain, take on and off, (yeah right) etc.  That's when I decided to use 3/8 plate. It was only 308 bucks for a 5x10 sheet.  Total material cost including paint is only 425 dollars.The completely unsupported  jutting out part, is not as much as it appears in the pics.  Only around a 8-10 inches.Last edited by lugweld; 01-18-2009 at 12:40 AM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Don't underestimate leverage.You got weight in the tractor, and you got force in maybe a tree stump.Sorta like you and the little lady doin' the mambo WALKIN' around the house.  She slips, and drops, somethin's gotta give  It's all about stiffeners, or stronger arms"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Well Samm, if its any reassurance,   I did jack the tractor up on that side and in the middle on the pan and had absolutely no give.But the pan is there for protection and energy absorbstion. Too much strength transmits the shock back to the tractor, making for some back wrenching blows.  Maybe that will be its "crumple" zone.  But as I said,  that is plenty of strength, with only eight to 10 inches of overhang.  There is more distance than that between the mounting tabs.I think I understand leverage.  I grew up in the bulldozer business.  A little tractor can fell a live oak with enough leverage.Last edited by lugweld; 01-18-2009 at 09:32 AM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldWell Samm, if its any reassurance,   I did jack the tractor up on that side and in the middle on the pan and had absolutely no give.But the pan is there for protection and energy absorbstion. Too much strength transmits the shock back to the tractor, making for some back wrenching blows.  Maybe that will be its "crumple" zone.  But as I said,  that is plenty of strength, with only eight to 10 inches of overhang.  There is more distance than that between the mounting tabs.I think I understand leverage.  I grew up in the bulldozer business.  A little tractor can fell a live oak with enough leverage.
Reply::d:d:d:d"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersamm...Worst case scenario..... Guy barks his shins on the plate under the step, slams the door and breaks the glass, which further enrages him, thereby causing him to drive over a large boulder, said plate bends thereby alleviating the original problem by closing the gap between bottom step and plate...
Reply:Well, the LugWeld  Shin Buster 2000 will be put in service on Monday. We will see...Sparky,  I am not completely sure of your question, but I will try to answer.Do you mean how did I get the plates to line up with the mounts?  Easy.  I positioned the pan into place once, I had made the measurements and the cuts. As you can see in the original pictures, it is being held up by blocks.  I leveled and centered it under the tractor.  I made the front mounting plate with the bolt holes my using a template method.  Then I mounted it and made a measurement to link the front mounting plate to the pan.  I cut a piece of metal and then welded it between the pan and the front mounting plate.  The other mounting tabs were fairly easy, as I generally would paint the bolt ends with a yellow valve action marker and "imprint" the bolt pattern onto the metal.  Where there was only holes to go by, I referenced the holes by measuring the spaceing and location of the holes from a y and x axis, drawing a short line for each measurement.  Where the lines crossed at a 90 degree angle, I centered my drill bit.  I oversized each hole by around a 1/16th of an inch to allow for any discrepancies.  Did not have to redrill any holes.Once drilled,  I bolted the mounting tabs on and welded comletely the outside facing edge of the tabs, to ensure accracy.  It would allow for some "drawing" out and away from the mounting points on the tractor when I unbolted it.  Better "drawing" out than "drawing" in.When I unbolted, I only had maybe a 1/16 of an inch draw which still allows plenty of wiggle room for the bolt holes.  I then proceeded to weld the inside edge after dropping the pan.  After doing so, all brackets are now square again or unchanged.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldDenrep, After rereading your post,  I see the tongue in cheek nature of it.  Didn't mean to get all techinical on ya.  But agreed.  It may become a source of pain, but it sits only 12.5 inches off the ground, so it becomes a step in and of itself.  The same could be said of the step sticking out.  I have known my shin or knee cap to contact a tractor step...quickly followed by rolling around on the ground holding the affected spot and screaming in an unknown language.
Reply:wow, great plate. i need to make one for my p.o.s. new holland tcd 45 and you gave me some good ideas. thanks.plenty tough and union made.
Reply:Originally Posted by lugweldWell, the LugWeld  Shin Buster 2000 will be put in service on Monday. We will see...Sparky,  I am not completely sure of your question, but I will try to answer.Do you mean how did I get the plates to line up with the mounts?  Easy.  I positioned the pan into place once, I had made the measurements and the cuts. As you can see in the original pictures, it is being held up by blocks.  I leveled and centered it under the tractor.  I made the front mounting plate with the bolt holes my using a template method.  Then I mounted it and made a measurement to link the front mounting plate to the pan.  I cut a piece of metal and then welded it between the pan and the front mounting plate.  The other mounting tabs were fairly easy, as I generally would paint the bolt ends with a yellow valve action marker and "imprint" the bolt pattern onto the metal.  Where there was only holes to go by, I referenced the holes by measuring the spaceing and location of the holes from a y and x axis, drawing a short line for each measurement.  Where the lines crossed at a 90 degree angle, I centered my drill bit.  I oversized each hole by around a 1/16th of an inch to allow for any discrepancies.  Did not have to redrill any holes.Once drilled,  I bolted the mounting tabs on and welded comletely the outside facing edge of the tabs, to ensure accracy.  It would allow for some "drawing" out and away from the mounting points on the tractor when I unbolted it.  Better "drawing" out than "drawing" in.When I unbolted, I only had maybe a 1/16 of an inch draw which still allows plenty of wiggle room for the bolt holes.  I then proceeded to weld the inside edge after dropping the pan.  After doing so, all brackets are now square again or unchanged.
Reply:Hey Sparky#1---  There's also another way to do it.  (always is)Direct measurement works.  What Lugweld did is fine.  He was bang on in this case.  BUT... you can make some pretty good errors using direct measurement in your layout.  There's an inherant error in every measurement, line drawn, and punch mark.For something like this I like to use a transfer punch.  There are two kinds of transfer punch.  One is a regular punch, and one is a blind punch.  The regular punch is for when you have free access to both sides of the hole that you want to copy.  You lay your workpiece on a flat surface, lay the mating part on top of it, insert the punch thru the mating piece bolt hole, and give it a whack (just hard enough to make a dimple)The blind punch is for times that either you can't put something thru the hole, because it's a blind hole..........or when you can't take the mating piece and lay it on top of the workpiece (Lugwelds sittuation).  You ain't flippin' the tractor on it's side to mark holes  The blind punch is inserted in the hole, the workpiece is lined up over the hole with the insert, and you give the workpiece a whack to make the dimple.I'm a nut about not ruining transfer punches.  They ain't center punches!!  They're one of a kind punches that fit a certain size hole, and it's expensive to buy replacement punches for a particular hole size.  They come in sets to fit a wide variety of holes.  SAE, or metric.  Hit the damn thing just hard enough to make the smallest dimple that you can spot with your eyes.  Using machinists blue layout ink can help.  Coat the part with the ink, and any scratch/dimple shows up clearly.The beauty of the punch is that we're not fartin' around with lines, X's, etc....  You get the exact center of the hole that you wanna drill.  Oversizing the hole is a good idea in order to compensate for distortion when welding.In the OP's case...... I would have inserted the blind hole punch in the bolt hole, then marked the brackets, drilled the brackets, bolted them to the tractor, then tacked the plate to the brackets, lowered the plate, and finished the welds.  You can fool around with the surface that meets the plate to make it fit nicely, but at least you know that your're working from a fixed point.  Being able to fit the bolts thru the holes is the critical part of the bracket.  You can always grind the welded side of the bracket to make up for any differences.It sounds like a lot of work, but really it's pretty simple, and it beats the frustration of misaligned holes and creating scrap Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-23 09:32 , Processed in 0.090370 second(s), 18 queries .
