Help anyone know about this welder. Cemont.
发表于 2021-9-1 00:13:48 | 显示全部楼层 |阅读模式
Ok here is the deal, I am able to pick up this 220V mig welder for 40$ without the gun. The dude knows little about it and it needs work to get running . Anyone know anything about this company/welder. I have found out that they are over seas . But thats about it. I mean for 40 bucks can i really go wrong. I new to welding and this will be my first welder. Pics to follow . Cheers http://img297.imageshack.us/my.php?i...3460033mc9.jpghttp://img183.imageshack.us/my.php?i...3460034ld5.jpg
Reply:You may find that your 40bucks will lead to more than what you bargained for. If getting a gun and parts is expensive or hard to get.....you may have been able to use the money for a Lincoln that would be supported by almost every major welding supplier around.Or...one of those blue boxes they call Miller. Even that might be a possible solution. Good luck if you can get it all together for under 100bucks. Otherwise I would pass.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:That looks like one of those Harbor Freight welders. You may want to pass on that one.  If you're new, you'll have a helluva time figuring if your welding or your welder needs fixing.
Reply:Googled them and top spot was the company.http://www.telfordgroup.co.uk/acatal...a_Cutting.htmlUk based joint.Give them a call and see what they can do. May be as simple as a Tweco style gun replacement.Last edited by Hammer; 01-19-2009 at 07:44 PM.
Reply:if the welder is from the UK you might ask some one on this forum this are some nice people http://mig-welding.co.uk/forum/index.php?
Reply:Thanks I logged on over there and will see what they say. Thanks guys
GMT+8, 2025-12-23 11:04 , Processed in 0.155364 second(s), 18 queries .
