Knives from hay mower blades
发表于 2021-9-1 00:13:47 | 显示全部楼层 |阅读模式
Last summer after doing some repair work on a hay mower, the rancher gave me a bucket of mower blades. I didn't know what I would do with them but they were metal so I took them and put them in my bone pile. I finally came up with an idea a few weeks ago with what to make out of them--knives. They are a little different than most knives but they work well for what they are intended for.The first two I made had a hook like blade like a gut hook. I gave one to the rancher that gave them to me to use for cutting the wrapping off of round bales when he feeds. When his neighbor seen it he had to have one as well. I didn't get pictures of those. I just recently built another to be used as a skinning knife. It has a good swept up blade and worked well on the last deer I killed. With the finger hole you don't have to put the knife down while pulling on the skin.
Reply:Nice design!!DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Slicker then snot on a doorknobA butterfly without wings, is just an ugly bug
Reply:By the looks of your hand, I'd say it'll cut human skin anyway....Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:It looks a lot like the blade from a Corona pruner, with a much larger pivot hole and the handle missing.The big question is: Can you shave with it?
Reply:prison inmates will be intrigued... Fire!, Fire! Oh wait, that's my torch...Lincoln PT-225 TIGLincoln 175 MIG
Reply:Good idea for use of old metal!  That blade looks just like an ulu  (Knife used by Eskimos).Nice job!-MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:These blades are made out of really high quality, German or Swiss steel usually.  Too bad, you didn't get hold of some of the really long ones that are completely flat.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:My father had something like that from World War II. They called it a Knuckle Knive. Not sure if it was used like brass knuckles. He said it was used for close quarters fighting.My Wood's Dixie Cutter has 24" blades on it. 1/2-5/8" thick they would make one heck of a bladeCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
GMT+8, 2025-12-23 09:32 , Processed in 0.094593 second(s), 18 queries .
