Welding mild steel to hardened steel
发表于 2021-9-1 00:13:45 | 显示全部楼层 |阅读模式
I'm trying to weld some braces (mild steel) to the back side of a snow plow cutting edge (hardened steel).  I'd like to mig weld them with my mild steel wire.  I've been told that the best bet would be using a 7018 electrode and preheating the steel.  Do you guys think I'll have any luck with my mig machine, or should I just go with the stick electrode for best outcome?  Thanks for any tips, Nick.
Reply:first of all...what kind of plow is it?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:snoway
Reply:well i have no clue what a snoway plow looks like.. can you post a pic of what your trying to do?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I can't post pics now, but here is the jist of it.  I need extra height out of my plow.  plow mount on truck is too high.  Going to mount another cutting edge onto the original cutting edge for extra height.  I want to weld braces made from either flat bar or angle to the back side of the old cutting edge(making it permanently attach to the plow) and to the back of the plow blade frame.  From the increased cutting edge length, I will have increased leverage to bend the plow where the original edge bolts to it.  I am trying to make the bottom of the old edge stiff so the extra leverage won't bend anything.  Still the basic question, mild to hardened.  Doable?
Reply:well i know with a fisher cutting edge it is hardend..but only on the outside..about .030 deep..if the whole edge was hardend all the way through it would just snap when you hit your first sewer cover.. so i say grind about .030 off where the weld is going and go from there..no pre heat..no post heat..a mig should do the job..but i'd use 7018 with a stick welder..if you can then go that route.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Are the cutting edges actually hardened? I was told that they were roll formed which is harder than cold rolled steel but not as hard as hardened steel. I just used a couple of pieces of cutting edge from a meyers plow to make some brackets to lower the undercarriage of my snow plow setup and I was able to drill them and weld them without a problem.Sure, I can fix it... I got a welder!!!
Reply:I'm not exactly sure if it is hardened or not.  I'm looking into it now.  I do know that I had a really hard time drilling holes in the edge, and had to eventually take it to a machine shop and have them drill the holes.  I will give it a shot and see how it goes.  If the steel is going to crack on the cool down, than it should probably do it right away.  If it doesn't weld well, then I'll have to think this one through a bit more.
Reply:Originally Posted by fwalz3Are the cutting edges actually hardened? I was told that they were roll formed which is harder than cold rolled steel but not as hard as hardened steel. I just used a couple of pieces of cutting edge from a meyers plow to make some brackets to lower the undercarriage of my snow plow setup and I was able to drill them and weld them without a problem.
Reply:Ok, so I found out that the cutting edge is C1080 high carbon steel.
Reply:Well, I don't think it is going to work very well.  I tacked a piece on and then gave it a whack with a hammer.  The weld broke away on the cutting edge side.  It tore the steel off.  I can only imagine the same thing happening while I'm pushing snow.  It would be worse backdragging.
Reply:Hey zap is what case hardening is?
Reply:If the old cutting edge is a bolted on simple flat shape, could you replace it with low carbon steel?  Maybe you could get your new height, strength and cutting edge mount out of one well thought out clean design. And… maybe reuse that edge you where going to weld up.
Reply:Originally Posted by denrepIf the old cutting edge is a bolted on simple flat shape, could you replace it with low carbon steel?  Maybe you could get your new height, strength and cutting edge mount out of one well thought out clean design. And… maybe reuse that edge you where going to weld up.
Reply:Originally Posted by Nick KentWell, I don't think it is going to work very well.  I tacked a piece on and then gave it a whack with a hammer.  The weld broke away on the cutting edge side.  It tore the steel off.  I can only imagine the same thing happening while I'm pushing snow.  It would be worse backdragging.
Reply:Originally Posted by jdwelderHey zap is what case hardening is?
Reply:Originally Posted by lotechmanNow that you know it is simple carbon steel rather than some complex manganese or chromium alloy, things are simpler.  The test you did is a standard way to check your preheat.  Fire up a tiger torch and heat the edge until spit dances on it.  Tack weld your piece on with a one inch bead and let cool.  If you can snap it off with the bead tearing out the carbon steel then you need even more preheat.  If the weld holds and bends a bit or even breaks in the bead of the mild steel piece then you will have reasonable success with your modification.  You still should use E 7018 at the very least.  I would be inclined to  use E 8018.   If you tack the assembly together cold keep in mind that every tack will be a crack site.  It is best to warm the assembly when tacking.  Locate your tacks so that they can be ground out as you weld up the unit hot.
Reply:Originally Posted by Nick KentI'm trying to weld some braces (mild steel) to the back side of a snow plow cutting edge (hardened steel).  I'd like to mig weld them with my mild steel wire.  I've been told that the best bet would be using a 7018 electrode and preheating the steel.  Do you guys think I'll have any luck with my mig machine, or should I just go with the stick electrode for best outcome?  Thanks for any tips, Nick.
Reply:It sounds like AR plate. Abrasive resistent. I would heat it up to over 70 and weld it with 7018. It doesn't need alot of heat, just enough to keep it from being a cold weld. The Mig will cause it to crack under stress. Or even go with a flux core if you want to use wire.
Reply:Originally Posted by Robo48Nick I currently own a snoway 29 series plow. How much to high is the truck?? The A frame on the plow should be about level when the blade is down it can have some angle downward to it as well. The push bar on the truck is adjustable and should be about 11" high (I think measured from the bottom of the bar). I am assuming you put a lift kit on the truck is the reason why the truck is to high?? You could try adjusting the height of the pushbar?? When you add the extra cutting edge on the plow you are going to change the length of the lever arm of the tripping action on the moldboard effectively weakening the springs on the blade. Therefore if will trip easier and you will want some sort of compensation.  Also the cutting edge takes the grunt of the abuse on a snowplow and IMO will have a hard time holding up as a two piece blade. It seems with snowplows nothing is 1 dimensional. Hope this helps you.
GMT+8, 2025-12-23 09:31 , Processed in 0.072258 second(s), 18 queries .
