stick polarity
发表于 2021-9-1 00:13:43 | 显示全部楼层 |阅读模式
when welding with 6013 what  advantages are there between ac,dc-,dc+
Reply:On AC there is no arc blow.  I like '13 on straight polarity, electrode negative.  it seems to run slightly smoother than reverse.
Reply:I use straight polarity for 6013, also.  I have a little Thermal Dynamic Dragster 90 amp inverter. There is a noticeable difference between that straight and reverse polarity.  I guess because I am usually welding at the top end.I works well on AC.  I use it quite a bit in the shop.Last edited by tapwelder; 11-24-2006 at 01:55 AM.
Reply:6013 can be run on DC + or -.DC + will give you a little more penetration.DC- will give you a little more smoother weld and more disposition.It works well on either polarity.Here in the Great White NorthMosquitoes can't fly at 40 below
Reply:In theory, electrode negative DCEN should result in the lowest penetration, best for thin stuff.  AC would be a little deeper, and DCEP the deepest.
GMT+8, 2025-12-23 11:04 , Processed in 0.110488 second(s), 18 queries .
