Rod holder
发表于 2021-9-1 00:13:39 | 显示全部楼层 |阅读模式
So everyone else is making them, so I decided to get better organized in my messy corner.  I CNC plasma'd out the upper and lower plates, connected them with 1/2" angle, painted it gold and bolted it to the wall.  It holds 17 tubes which is just enough that I have a few open spots left over. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Man you got a lot of rod.Filler rod.Yup
Reply:Originally Posted by BurnitMan you got a lot of rod.Filler rod.
GMT+8, 2025-12-23 09:32 , Processed in 0.099448 second(s), 18 queries .
