Bucket Repair
发表于 2021-9-1 00:13:39 | 显示全部楼层 |阅读模式
cat bucket installed partial rear wall and new caps Attached Images
Reply:Did you form the piece or was it a prebent insert that you bought?  If you formed it,  how thick is it and what process did you use.?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:That looks real good! Nice job. City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:that looks great!
Reply:Very Nice work. I get farmers that go to auctions and buy backhoe bucket that don't fit the boom , the pins aren't spaced right, or pin holes are different than what they need. So they come to me to make the bucket fit their backhoes.  I also Have bought several different buckets and converted them over to fit my Ford New Holland 555E backhoe.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:i also redo buckets to fit differnt machines i enjoy it. i hade a shop bend the caps it is ar 400 1/4
Reply:How crucial are the pin pivot points?Do you align them to the machine(taking into account wear, bending, etc), or just make sure they're trammed/aligned as the bucket sits(ie., like a brand new bucket)?  Hope I phrased that right.I'll never do anything this size, but it's always a source of worry when I fix an old part that's been on a piece of equipment for a long time."Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-23 09:35 , Processed in 0.106386 second(s), 18 queries .
