A customer wanted to mount his generator on top of his hitch, under his camper. So I got all the measurements I needed and made it. It pins though the top of the drop hitch. I had to use smaller square tube with shims to get the right fit. I also put a latch so he can lock it. He rino coated it and plans on insulating it with dynomat. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Thats slick......does it still get the air it needs for cooling?Yup
Reply:Yeah, I cut a hole on the left side for the exhaust. He said he ran it for quite a while on his last trip with no problems and can hardly hear it.Common sense in an uncommon degree is what the world calls wisdom.
Reply:hey did u also leave the bottom open cuz the air cleaner is on the bottom on the honda 2000 i now work for a lawn mower repair shop in the city i live in and form what i have learned is that those breath for the bottom. it duz look quite secure from what i can see and it looks goodjust some friendly advice later agwelderold skool idealarc welderEsab multi tool Milwauake 7inch angle grinder the best of all tho the oxyacceteline set up
Reply:I never thought about the intake. I wouldnt imagine that it would be an issue since I cut so many holes in the box. If anything, that would aid in the cooling since it's drafting from all around the unit.Common sense in an uncommon degree is what the world calls wisdom. |
