Stuff For A Waste Treatment Plant
发表于 2021-9-1 00:13:38 | 显示全部楼层 |阅读模式
Good thing we are on the new end of this project, they are 10' long by 6' wide before the flare at the top.Parts.Setting up to pick, pad eyes and such. First pic is a plate dog to flip it over so I can weld on a pad eye.Flying the sides to the base.Tacking.Angle of the dangle 38 degrees.Skip welded with .045 Tripple 7 on the outsideSeal welded on the inside.Next postDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Done.All of 10 of em' done.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Those are some good lookin welds with that Triple 7
Reply:It welds like "buddah'"Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Tozzi, the KING of Triple 7!Looks good.  David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:I am king of nothing, I just do it all. Get yourself a roll, you will love it.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:SmOOOOOth !That looked like fun.
Reply:holy crap...  cant begin to imagine how much crap thats gonna holdlike how you lifted it into postion
Reply:pretty neat Tozz.  Big stuff-Graham-Mechanical EngineerAutosport Mechanic/Fabricator
Reply:tozzi what is this triple 7 wire who makes it? sorry I  never heard of it looks like it welds beautifuly  is it flux or solid?250DXMM251MM175225G plus 251D-1
Reply:I couldn't help notice it is to be galvanized??  Is the stitching on the outside ok?  Or is it not finished yet?
Reply:Very nice job. I like the angle finder I saw in one of the pictures, and would like to get one. It looks like it has the degrees at the bottom. Could you please tell me what kind it is and where did you purchase it. Thanks for the info and the pictures.
Reply:Triple 7 made by Tri Mark, the angle finder is a Starret, I think MSC has em'. As far as the stitch welding on the outside it is fine, they are getting encased in concrete.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingTriple 7 made by Tri Mark, the angle finder is a Starret, I think MSC has em'. As far as the stitch welding on the outside it is fine, they are getting encased in concrete.
Reply:Another huge job.You guys are single handedly usin' up all the iron ore on the planetHandy overhead craneAnd you're welcome to that weather up there"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Boy, if you weren't on the clean end of this job, it would make that column job you just did smell pretty sweet!Here is what I have so Far:Miller:Shop Master 300 A A/C D/CS 22a Wire FeederRFC-14 Tig PedalHF-251D High Freq. UnitProfax 250 A Mig GunVictor RegulatorsHarris:63-2 torch Cutting Attachment 49-3making home built tig cooler
GMT+8, 2025-12-23 09:33 , Processed in 0.121435 second(s), 18 queries .
