MIG vs Flux Core MIG
发表于 2021-9-1 00:13:35 | 显示全部楼层 |阅读模式
Hello All I am new to the site  and new at welding.. Which is a better weld Flux Core MIG or MIG using Argon?Also when welding if you have to weld vertical should you start at the top ot bottom?
Reply:Originally Posted by us7raceHello All I am new to the site  and new at welding.. Which is a better weld Flux Core MIG or MIG using Argon?Also when welding if you have to weld vertical should you start at the top ot bottom?
Reply:Keep in mind that some flux-core wires are meant to be used inside because of the gas-shielding they require. They will be a lot easier to handle if you got a lot of vertical to do. Remember that flux-core wire don't go well with pure Argon too. Go with C25 or CO2. For the gasless flux-core wire, I never had fun with that. It sparks, spatters and welds like $h..
Reply:I am welding my frame on my S10..I narrowed it from 40" to 24" I have most of it boxed in already but I was having trouble trying to vertical weld starting at the bottom so I tried to start at the top with Great results.But I do want to do things proper so if welding vertical starting at the bottom is the proper way then I guess I need more practice  The frame is 1/8th" and so is the metal I am using to box it in.
GMT+8, 2025-12-23 04:07 , Processed in 0.101426 second(s), 18 queries .
