Backing plates
发表于 2021-9-1 00:13:33 | 显示全部楼层 |阅读模式
This may seem like a strange question, but, are backs strips used much in the US?I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:Use of backing strips depends on code and local preferences.  I have used them a lot where the print calls for them.  In hollow sections such as structural tubing it makes for a faster and more convenient weld than trying for open roots.  I have rolled thousands of backing rings for various sized steel pipe pilings ranging all the way up to 2 metres in diameter.  I'm not in the U.S. but have done a lot of work intended for installation below the 49th parallel.
Reply:yes backing strips are usedChuckASME Pressure Vessel welder
Reply:I use em every chance I get.
GMT+8, 2025-12-23 04:04 , Processed in 0.102811 second(s), 18 queries .
