Steel to cast iron
发表于 2021-9-1 00:13:30 | 显示全部楼层 |阅读模式
Got a motor block with a hole in the side and was just wanting to patch it with a piece of steel  wat would be the best process? and certain king of steel need to be used? got any tips or anything that would help thanksMiller Bobcat 250MillerMatic 250 w/ SpoolgunMiller Spectrum 623 X-tremeMiller Regency 250 /SpoolgunComplete Machine Shop
Reply:How do you plan on welding this?That's a big help....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:i figured the best way to go would be to either flux core it or use a nickle rodMiller Bobcat 250MillerMatic 250 w/ SpoolgunMiller Spectrum 623 X-tremeMiller Regency 250 /SpoolgunComplete Machine Shop
Reply:From one extreme to another...Use the nickle rod in that case..Tig is the way to go with 309 filler......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:i would tig it but my new machine wont be here till first of the week so i guess ill just have to use a nickle rod  any specific steel that works the best in this application?Miller Bobcat 250MillerMatic 250 w/ SpoolgunMiller Spectrum 623 X-tremeMiller Regency 250 /SpoolgunComplete Machine Shop
Reply:Originally Posted by D&D MetalsGot a motor block with a hole in the side and was just wanting to patch it with a piece of steel  wat would be the best process? and certain king of steel need to be used? got any tips or anything that would help thanks
GMT+8, 2025-12-23 04:05 , Processed in 0.107615 second(s), 18 queries .
