Apologies to the ornamental rail guys. I make the ugliest caps on the planet.Started back to work on the latest fiasco today. Nice warm day, but too windy to make decent welds, so decided to take care of the 8 caps I need. I hate capping tubing, and it hates me Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Looks good to me.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Me too.It's only rusty in the middle and the paint will hide that.A butterfly without wings, is just an ugly bug
Reply:Gee sam are you entering a welding contest with that thing? It looks good! Clean the rust put some spot putty in any depressions, let dry, sand, and paint.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.& 2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Samm - Try the plastic caps that fit into the tube unless it's pretty big size tube.. When we build gates and the customer wants it cheap, like most dowe just use the plastic caps and call it a day!Miller 252Miller 250Miller Syncrowave 250Esab Plasma Powercut 1250HF Basic oxy/act torches
Reply:Originally Posted by FluxThisSamm - Try the plastic caps that fit into the tube unless it's pretty big size tube.. When we build gates and the customer wants it cheap, like most dowe just use the plastic caps and call it a day!
Reply:Ahh, ok.. Well it looks like a really clean job on the grinding!Are you going to start a build thread on the skid build?Miller 252Miller 250Miller Syncrowave 250Esab Plasma Powercut 1250HF Basic oxy/act torches
Reply:I sorta did, and Oldtimer told me to quit talkin', and start buildin'It's the weather that kills me. Has to be good weather, or the "shop" is shut down"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Newbe question….How do you cap tubing? How do you hold the cap while it is being welded? I am looking for some tips and tricks for capping….
Reply:Originally Posted by BilldacatNewbe question
Reply:Originally Posted by farmersammI sorta did, and Oldtimer told me to quit talkin', and start buildin'It's the weather that kills me. Has to be good weather, or the "shop" is shut down
Reply:Thanks for taking the time to post pictures and the advice. I could probably handle that with MIG, but the real test is running 6013...My stick skills are getting better but I need some serious pratcice running vertical. Lincoln 175HD MIGCraftsman 230/180 AC/DC stick. (circa 1990's) |
