Got a little work done today
发表于 2021-9-1 00:13:21 | 显示全部楼层 |阅读模式
Frame for the floor, welding skid.I'm still crazy about the 7018Seemed to run pretty consistantly, but with a little more spatter, and a slightly rougher bead today.  The can is going on a month old.  And winds were running around 25 today.  I don't know if it's a function of separate things, or a combination.Had to tie a boat anchor to my butt to keep from movin' around in the windThe corner tie ins on the tubing are consistent weld after weld after weld.  It's the first time I've been really confident in a good watertight seal.  Woo Hoo!!!!!!!!!!I love this stuff  Gonna give the can a big ol' smooch Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Looks good to me. The more you use 7018 the more you will like it and before you know it the slag will be peeling off. Keep tweeking the machine until you find that sweet spot.
Reply:Samm,That is good enough for gub'ment work...lol... I think it is just about as good as you can make it.  MAYBE a little cool, but that could be that the steel is 20 degrees or something.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldSamm,That is good enough for gub'ment work...lol... I think it is just about as good as you can make it.  MAYBE a little cool, but that could be that the steel is 20 degrees or something.
Reply:Looks good from here!! Nice work samYa gotta spend money to make money!
Reply:Originally Posted by cajun welderLooks good to me. The more you use 7018 the more you will like it and before you know it the slag will be peeling off. Keep tweeking the machine until you find that sweet spot.
Reply:Samm, my el-cheapo craftsman is infinitely adjustable.
Reply:Lookin GOOD FarmerLincoln 255XT Power Mig        Lincoln Precision Tig 225Hypertherm Powermax 30
Reply:I think the craftsman welders are made by some pretty reputable manufacturers.  It could be a Miller, or some other brand.  I think Lincoln may even be branded craftsman once in a while.  I'm not too sure.What I'm sayin'..... it ain't an el cheapo DaddyLast edited by farmersamm; 02-05-2009 at 09:21 PM.Reason: last sentence"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammDamn crackerbox only goes a click at a time.  105, 115, 125 on DC.  Even wider range on AC.I'm startin' to lean towards Miller.OK, I SAID IT!!!!!  The Thunderbolt is infinitely adjustable, instead of click adjustable.
Reply:Samm,Don't listen to Duane.  That Lincoln has made you a better welder as a result of  the lack of adjustment.  The thunderbolts are only for sissies who like things like manscaping and manicures and a roll of dental floss in their front shirt pocket, next to the pens in their pocket protecters.  You have learned an invaluable skill that a thunderbolt fails to teach: how to vary the arc length to get the most out of a rod.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldSamm,Don't listen to Duane.  That Lincoln has made you a better welder as a result of  the lack of adjustment.  The thunderbolts are only for sissies who like things like manscaping and manicures and a roll of dental floss in their front shirt pocket, next to the pens in their pocket protecters.  You have learned an invaluable skill that a thunderbolt fails to teach: how to vary the arc length to get the most out of a rod.
Reply:OMG!!!!!!!!IT'S HAPPENING AS WE SPEAKReally just hot roast beef sandwich for supper.Whew!  Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Looks real good, Samm!!! Don't let those others razz ya too much. I'm one of those "wussy" thunderbolt owners and I love it. And,yes, I learned on some pretty crude welders. For the record, I have two "BLUE" ones, the thunderbolt and a 175 MIG. I'm still lookin' at plasmas, haven't decided yet. I keep reading threads on the various ones and comparing.                               MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Weldingweb............ Home of the digital camera, pic freaks, and just plain idiots(me)"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by duaneb55HEY CRAIG!!!!  Ya hear that?!It's either cabin fever catching up to him or an overdose on fresh air and sunshine today.Maybe he stopped smokin' and he's just thinking more clearly now.FYI Samm, the Lincoln Idealarc series has units similar to the Thunderbolts if you're not sure you can quite make the step up to a... Miller.One step at a time.
Reply:Originally Posted by farmersammI'm startin' to lean towards Miller.OK, I SAID IT!!!!!  .
Reply:Maybe these red and blue welders are like the red and blue states. OOP!!!, this is the wrong place to say that.                            MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
GMT+8, 2025-12-23 04:03 , Processed in 0.176311 second(s), 18 queries .
