What electrode do you recomend?
发表于 2021-9-1 00:13:16 | 显示全部楼层 |阅读模式
What electrode do you recomend to weld a 3 inch long crack, in a garden shovel?
Reply:Unless you  are very experienced ,in welding sheet metal thickness with electrodes do not try it. A 2mm 6012 (don't know your  inch fractional size ) would have to be the last resort. A mild steel  oxy acetylene filler wire applied with same of course will do the job.Next best is mig with a fine filler wire.Grahame
Reply:I would weld a 1/2" piece of thin strap steel along the back of the crack to reinforce it.  It won't hurt your shoveling a bit.***************************************Lincoln AC225 stick welderLincoln HD100 WeldPak flux core wire feed welderThree of the cheapest grinders money can buy
Reply:Just to get a better picture, where is the crack?  Is it in the blade (running from cutting edge), or the step, or the shank?  What I'm getting at; Is it absolutely imperative that you weld it?  Does the crack limit the shovels effectiveness or make it unsafe to use?  Of course, you could always run a bead on each side with a small diameter (1/16 or 5/64 inch 6013, and smooth down the beads a tad (The dirt doesn't care what the finished quality of the welds are!)Good luck,cricman
GMT+8, 2025-12-23 04:03 , Processed in 0.092604 second(s), 18 queries .
