help welding nibral
发表于 2021-9-1 00:13:10 | 显示全部楼层 |阅读模式
I work at a small boat yard and frequently I have to weld brass and or bronze nuts to nibral wheels. We use only a stick welding machine. Nothing seems to work all of the time. What kind of stick rod should I use?
Reply:i weld nibral all the time, but only use Tig with  2% tung. with argon gas and weld it as if welding SSi use nibral filler from McDurom Dist. out of michigan   www.mcdurmon.com but sure it can be ordered from your welding supply
Reply:Have you considered brazing?  That is usually the best process for joining dissimilar alloys.
Reply:they make an electrode for this.  i found in a search was:     weld-mold 4046 hope that helps
Reply:Another filler sourcehttp://www.ampcometal.com/common/dat...926879fbd93073
GMT+8, 2025-12-23 04:03 , Processed in 0.084747 second(s), 18 queries .
