Wheel
发表于 2021-9-1 00:13:09 | 显示全部楼层 |阅读模式
A customer was hauling 6tons when his tire blew.. he was almost home so he drove the rest of the way.  This is how his rim turned out.  He had plans to use it as the hub for a 22", so I setup the plasma on a small turn table and burned off the sides.  On the straighter side, I could set the plasma on latch mode and mount the torch so I could turn it in one continuous move without having to hold the handle. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Holy shnikes......looks like a flower!!!!Lucky the truck didnt turn over.Miller blue star 2eLincoln 175
Reply:A 22" What?A butterfly without wings, is just an ugly bug
Reply:a 22 barrel probablythe barrels are usually heated up then the centers pressed in and welded
Reply:Ingenious fixture Brainfarth!Brainfarth maybe means a 22.5" Dayton style wheel? There is also an odd-ball  22" wheel too, but that's actually larger ID than the "drop" of a 22.5" and the center he just cut out probably wouldn't fit in a 22".Good Luck
Reply:Originally Posted by chrisbmx68a 22 barrel probablythe barrels are usually heated up then the centers pressed in and welded
Reply:Those look like good old Made In USA Vise-Grips ya got there Brainfarth.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-23 04:05 , Processed in 0.092394 second(s), 18 queries .
