Chicke Salad outa chicken ****
发表于 2021-9-1 00:13:08 | 显示全部楼层 |阅读模式
I was asked to fix this.  Its too long of a story, but this is what I got to work with.I ground it all off with a 4.5" Dewalt and die grinder with a carbide burr.  Heated it with a propane torch and wire brushed all the paint and crap off....Put a fresh smooth layer of weld over the whole mess, filled a bunch of holes and ground it smooth again.   Some primer and sort of red paint...SP100 on E4 or C3, C/25, .023 wire 6 Lpm (13 cfh)  Harbor freight helmet I aint no body man..... But no one will see it.....I charged him an hour.  I also adjusted the door......With a floor jack and a 4X4  DavidLast edited by David R; 02-10-2009 at 08:38 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:great thinking and repair as usual...Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:OWWWW the pain make it stop. Dave, I am sending you a case of beer. On a lighter note I did a Blazer before it got that bad.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:The hinge pin holes were worn out.  I wanted to fix them, but all he cared about is how it looked and the door shut.  Thanks DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I would have welded the door shut.
Reply:did that to a guys locker at work... he thought it would be funny to put neverseize all over my lock on my locker.. so i made it really difficult to get into his!!!    full bead all the way around .....  he had to cut the door off.. get his smoking burning crap out of his locker and find a new one
Reply:Originally Posted by SandyI would have welded the door shut.
Reply:looks like the previous repair consisted of puke and paint...
Reply:Sad part is that looks like a fairly nice truck.   Did you tell that guy to smash his welder?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Liked it better the way it wasIt had more..........CHARACTER"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Looked more like J.B. Weld...
Reply:You didn't cut the (old) crap out and then put a patch piece in place?  You just ground out the old rough 'weld' and then did some weld bead build-up and then a quick hit with the grinder to smooth the new good welds down flat, and then primer-n-paint?And just how did you keep from melting/burning all the meltable/burnable stuff right next to the repair area?  Like the plastic trim, and the plastic hose leading to the other door, etc?And JB-Weld is usually MUCH smoother than that original pigeon-poop.    The best laid schemes ... Gang oft agley ...
Reply:Originally Posted by weldbeadlooks like the previous repair consisted of puke and paint...
Reply:Originally Posted by MoonRiseYou didn't cut the (old) crap out and then put a patch piece in place?  You just ground out the old rough 'weld' and then did some weld bead build-up and then a quick hit with the grinder to smooth the new good welds down flat, and then primer-n-paint?And just how did you keep from melting/burning all the meltable/burnable stuff right next to the repair area?  Like the plastic trim, and the plastic hose leading to the other door, etc?And JB-Weld is usually MUCH smoother than that original pigeon-poop.
Reply:Nice fix!! Why the harbor freight helmet? No vista?Ya gotta spend money to make money!
Reply:Originally Posted by welderShaneNice fix!! Why the harbor freight helmet? No vista?
Reply:if i said it once i said it a thousand timesyou can not polish a turd,,,
Reply:Originally Posted by weldbeadif i said it once i said it a thousand timesyou can not polish a turd,,,
Reply:not to hijack , David, sorrythanks to you dswi dont agree the myth is  busted. they took lion and ostrich poop, reformed it, and that doesnt count...turds have corn and  peanuts...the myth still stands...
Reply:Well, this one's goin' into the toilet........."Any day above ground is a good day"http://www.farmersamm.com/
Reply:And where will YOU buy YOUR next used car???"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by David RThe hinge pin holes were worn out.  I wanted to fix them, but all he cared about is how it looked and the door shut.  Thanks David
Reply:Elmer, "It doesn't look good!" Dilmer, "How can you tell?" Elmer, "I'm looking at it." Dilmer, "You can't tell anything by looking!" Elmer, "It smells bad too!"I like it! Nice fix.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by weldbeadnot to hijack , David, sorrythanks to you dswi dont agree the myth is  busted. they took lion and ostrich poop, reformed it, and that doesnt count...turds have corn and  peanuts...the myth still stands...
GMT+8, 2025-12-23 05:54 , Processed in 0.070157 second(s), 18 queries .
