Ramps
发表于 2021-9-1 00:13:07 | 显示全部楼层 |阅读模式
A fire department wants ramps so they can load some over sized people into the back of their ambulance.  The ramps are 4" x 12' aluminum channel with a hinge in the middle.  I beefed up the hinge area with another 1/4" plate.  Then I spread the ends open so it's easier to align the  tires to the ramp.  The supports are steel tube with plenty of holes for adjustment on uneven ground, tied together with a piece of 1/2" round stock.  They plan on powder coating all the metal pieces(wish I knew that before I spent all that time painting the uprights yellow).  You can see the pipe sticking up and laying down on the mounting angle.. That is to guide the cable for the winch.. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:that is awesome! great design!-NateMiller Trailblazer 302gMiller Spoolmatic 30aLN-25 x 2Idealarc SP200Hypertherm Powermax 600
Reply:Oh yeah... he didnt call them over sized.. Super Bariatric was what he called them.  I guess you reach the super class when you go above 700 lbs.   He said that the ramps you can buy are right around 4 grand.. and I threw these together for about 850 bucks.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Nice looking job,  great welding.  What's the liability issue, if any?
Reply:Nice job!Pretty damn sad commentary on this country when ya need a lowboy to go get a patient.  Next thing ya know they'll be puttin' Autocranes on the ambulances."Any day above ground is a good day"http://www.farmersamm.com/
Reply:What do you figure the total weight might be.  Patient and gurney??"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Have they given any thought to where to store the ramps? You might be able to pick up some more work putting in a door and under floor storage on the ambulance similar to what's used on U-haul and delivery trucks. I'm working on setting up something like that for the alum loading ramp I bought this summer, so I can keep the back of the work truck clear and still have it if I need it.
Reply:Since they fold and are only 6' at that point, they fit upright on the right rear compartment.   I'm not sure what the gurney weighs, but a local patient tops the scales at over 1100.  I'm not sure about liability since we are not warrantying anything.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by Brainfartha local patient tops the scales at over 1100.
Reply:Next thing you know, the ambulance will have to cross the scales at the weigh station to see if he is over his GVWR!Here is what I have so Far:Miller:Shop Master 300 A A/C D/CS 22a Wire FeederRFC-14 Tig PedalHF-251D High Freq. UnitProfax 250 A Mig GunVictor RegulatorsHarris:63-2 torch Cutting Attachment 49-3making home built tig cooler
Reply:Originally Posted by 1NormyNext thing you know, the ambulance will have to cross the scales at the weigh station to see if he is over his GVWR!
GMT+8, 2025-12-23 04:02 , Processed in 0.158558 second(s), 18 queries .
