Buzz Saw
发表于 2021-9-1 00:13:06 | 显示全部楼层 |阅读模式
Since I've decided to go to wood to heat my weld shop (oil prices), I searched for and found an old Cordwood (buzz) Saw.  It had a blown 8 hp B&S mounted on it.  I took all that junk off.  I found a gear box I could adapt a PTO to.  I made the mounts for the box, calculated pulley sizes for correct blade tip speed, bought the stuff for that. Installed mounts for 3 pt hitch, and bought a new PTO shaft.  Originally, the thing didn't have any blade guard, so I fabbed that too.  Made the outside shield hinged so I can get the blade off for sharpening.  I just dug it out of the barn yesterday.  Thought I'd post a few pics.  One pic is of a couple of welds, painted. Attached Images
Reply:now that's a saw very nice-Graham-Mechanical EngineerAutosport Mechanic/Fabricator
Reply:nice saw is that a 24" blade
Reply:WOW. What a saw!! I would hate to slip when using that sawYa gotta spend money to make money!
Reply:Wow.  That thing has horror movie written all over it.  Does it vibrate much during use?Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:I'm scared of it already. I live in texas so not much need for heat.....not that bad. I'd like to see it in use.
Reply:Originally Posted by OUCHthatshotI'm scared of it already. I live in texas so not much need for heat.....not that bad. I'd like to see it in use.
Reply:And here's a You Tube video of one in use.  You can see how fast these things will cut small logs.  I cut up to a size diameter that I can safely pick up.  Trying to cut the smaller stuff with a chain saw is a real PITA.   The one in the video runs from a flat belt.  Requires a flat belt pulley installed on the tractor PTO Shaft.  I believe mine used to be driven that way as there are set screw marks in the center of the arbor shaft.  The one I used as a kid was mounted on the front of a John Deere B, flat belt driven up the right side of the tractor.  [ame="http://www.youtube.com/watch?v=WbMlLfYsi2g"]http://www.youtube.com/watch?v=WbMlLfYsi2g[/ame]
Reply:That thing is bad *** i wonder what osha would think of it [WHO CARES}
Reply:Here's an even older tractor driven saw.  This one DOES scare me.  Not a buzz saw though.  And, I don't think I'd be standing where that dude is in the event the blade gets bound, and parts start flying. Attached Images
Reply:Originally Posted by paweldorHere's an even older tractor driven saw.  This one DOES scare me.  Not a buzz saw though.  And, I don't think I'd be standing where that dude is in the event the blade gets bound, and parts start flying.
Reply:Not me"Any day above ground is a good day"http://www.farmersamm.com/
Reply:[QUOTE=paweldor;251890]And here's a You Tube video of one in use.  You can see how fast these things will cut small logs.  But will it do miters?A butterfly without wings, is just an ugly bug
Reply:That looks like a death bench seat.I bet it does great at trimming grass along the sidewalk.[ame]http://www.youtube.com/watch?v=Lg-oMULyn9s[/ame]>Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by BrainfarthThat looks like a death bench seat.I bet it does great at trimming grass along the sidewalk.>
Reply:Originally Posted by paweldorAnd here's a You Tube video of one in use.  You can see how fast these things will cut small logs.  I cut up to a size diameter that I can safely pick up.  Trying to cut the smaller stuff with a chain saw is a real PITA.   The one in the video runs from a flat belt.  Requires a flat belt pulley installed on the tractor PTO Shaft.  I believe mine used to be driven that way as there are set screw marks in the center of the arbor shaft.  The one I used as a kid was mounted on the front of a John Deere B, flat belt driven up the right side of the tractor.
Reply:dont think i'd want one i'd be temped to try it out, it'd be the one time it didn't work.  that's a cool idea though
Reply:I don't think I wanna be involved in operating any of those...MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Pawelder:Yep, been there done that. Growing up in Canada we had the same saw 30" no guard either. Cut a ton of logs for wood cook stove in house and sauna. Fell the trees in winter and skid them in. Our saw was belt driven. We'd cut all weekend then go for a nice hot sauna.Glad I don't need to do that anymore down here in East Texas.Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
Reply:Check this one out.[ame="http://www.youtube.com/watch?v=rpsza2NFLg8"]http://www.youtube.com/watch?v=rpsza2NFLg8[/ame]
GMT+8, 2025-12-23 04:07 , Processed in 0.092996 second(s), 18 queries .
