查看: 13|回复: 0
tacoma arm
发表于 2021-9-1 00:12:59 | 显示全部楼层 |阅读模式
i made these out of 4130 chromoly...Last edited by BuiltByBrooks; 12-13-2006 at 10:20 PM.
Reply:Wow...really nice work Brooks.What did you use to clean the tubing? It's really shiny for 4130.I see that it's for a 2wd frame....and from the way the Ball Joint plate is angled it looks to be for a lowered truck.What else are you doing (or have you  done) to the truck?- Paulhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:Nice work. Did you cut and bend the components as well?
Reply:Water jet or plasma?
Reply:*I used a tubbing cleaner at work that use is a fine grite sand paper.*The ball joint plate was laser cut at my work and i drew them on solid works.*The arms are for a 2wd tacoma that i bodydroped on 20's and i also put a lexas LS400 rear end on, stretch the rear window to make it full size, etc.There is to much to list. here are some more pics of it.....Last edited by BuiltByBrooks; 12-14-2006 at 08:01 PM.
Reply:I do all my work my self i'm trying to start up my own shop called Morbid INK.Where i want to do anything and every thing to trucks and cars...
Reply:Post some more pics as the project progresses..... looks nice!!_________________Chris
Reply:good stuff! keep posting!!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:That is impressive !!!!     Very nice job on that arm !Dan.Repair Specialties LLC
Reply:Hell yeah....Noww...is that the lower arm? How does inclining the ball joint helps for a lower? I would understand it if it was the lower arm....Nice work, inmaculate welding!  Did you pre or post heat treat it?My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:That's an upper arm, Elvergon.- Paulhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:good work ,more pic'sChuckASME Pressure Vessel welder
Reply:Dude that arm seriously looks like my grandma welded it.  Where did you go to school to learn how to weld?  Baby jesus is crying right now because of your poopy controbution to the welding industry!!!j/k Brooks!
Reply:hahahahaStrive For Perfection
Reply:That looks awsome.
Reply:looks great.not my favoret style for a truck, but i gotta admit its looking good.i always thought trucks should go up and cars go down. summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
Reply:Each Is Own, I like anything that is appealing to the eye....Strive For Perfection
GMT+8, 2025-12-23 04:04 , Processed in 0.073050 second(s), 18 queries .
