Santiary Welding
发表于 2021-9-1 00:12:59 | 显示全部楼层 |阅读模式
Looking for information on santiary welding.
Reply:what do you want to know...?sanitary welding covers many bases..i believe that if its clean it welds better..sanitary welds are so cool.. so... what are we planning?food service? waste disposal?medical?what?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Maybe he's talking about contaminated gear?  Did you wash your hands before picking up that torch?  dunno.
Reply:Sanitary welding often refers to food or drug industry piping and equipment.  There must be absolutely no undercut or grapes on the inside of piping.  Any notch will be a site for bacteria to grow.
Reply:i would say Tig it  and pruge it,good tight fit upwhat kind of metal will we be using?? SS
Reply:Originally Posted by prop-doctori would say Tig it  and pruge it,good tight fit upwhat kind of metal will we be using?? SS
Reply:I was a maintence mechanic in a pasta plant (DiGiorno)for a while. We didn't double joint anything. We purged and welded sanitary quick disconnect flanges on the ends of each pipe. Then we had to flipper wheel the inside of the pipe smooth at the weld. 90's and 45' were bought from a supplier already flanged up. The pipes were used to pump egg and water for the pasta making process. Each night the pipes were connected to sanitation equipment and sanitized.
Reply:Originally Posted by lotechman He was telling me that the regularly did coliform counts on the milk going through the piping.  When it started to climb then the system had to be sterilized again.
GMT+8, 2025-12-23 04:02 , Processed in 0.259383 second(s), 18 queries .
