SA200 rebuild
发表于 2021-9-1 00:12:55 | 显示全部楼层 |阅读模式
I'm in the process of seperating the rotor from the engine. I have followed the steps posted by KSELLON on AWS forum. When I got to step 8, which is removing the bolts connecting the  exciter bracket to the main gen housing, I noticed a cut out on part of the exciter bracket and a small square head bolt on top of the bearing housing. Is this a lube point or is it a screw to keep something secure? Does it need to come out before pulling the exciter bracket from the main housing?  So far every thing is going as planned and directions have been spot on.  I'll try to get some pics on here when I get it pulled apart.
Reply:There was a grease zerk in the older models.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Thanks. 1st order of business will be with the puller in the morning.
GMT+8, 2025-12-23 04:05 , Processed in 0.092281 second(s), 18 queries .
